has anyone disabled PE mode?
Old Jul 20, 2011 | 09:09 AM
DrX's Avatar
DrX
In EFILive PE enable is by TP vs RPM and a MAP threshold B3613. There are several PE modifiers.
I haven't used PE at all for a while.
With COS3 you can set the 100 kPa column of B3647 to the AFR you want to run in boost. This screenshot shows it in Lambda, but the table units can be AFR, EQ or Lambda. An EQ or Lambda of 1.0 in this table commands closed loop and uses the stoich value from B3601.
You can also use a combination approach so that B3647 defines the enrichment for lower boost levels and PE kicks in to provide additional enrichment at higher boost levels. Edit: This way you aren't running full enrichment at the times when your MAP is hovering around 105 kPa.
Old Jul 20, 2011 | 09:12 AM
Gadgetized's Avatar
Originally Posted by Wilde Racing
How does efi control pe? Is the table scaled using rpm or map?
They use MAP (kPa setting) TPS, and RPM. I will try and grab a screen shot after work. You basically set your VE map to a stoich ratio. Then you set PE for a given RPM. Then the throttle position % you have entered must be met and PE will activate once you are over the entered kPa. It seems that it would basically do the same thing if you just lowered your TPS down.
Old Jul 20, 2011 | 09:14 AM
Gadgetized's Avatar
Thanks DrX, beat me to it.
Old Jul 20, 2011 | 10:05 AM
Atomic's Avatar
I have a gauge for that
I use a hptuners 2bar SD OS and they have an additional boost enrichment table along with pe to add fuel based on MAP and not rpm like the PE table.
Blwn99x
Mar 24, 2023 11:14 AM
RustyD
May 23, 2016 07:04 PM
drummer0415
11
Oct 24, 2015 08:16 PM
MA$TER_E
Sep 9, 2015 03:14 PM
