has anyone disabled PE mode?
Old Jul 19, 2011 | 09:18 PM
Gadgetized's Avatar
Default has anyone disabled PE mode?
I have a semi OLSD tune, and have been debating to disable PE (performance enrichment) mode and making up for it on the VE, and boosted VE table. I have heard of people doing this, but do not know anyone who is using it. If anyone has done this, how do you like it?
Old Jul 19, 2011 | 09:24 PM
BlackGMC's Avatar
Resident Retard
It is om as lomg as you updated your commanded afr table to a richer value in the higher kpa (80-100kpa for NA). If you use efi live, custom operating system 3 (COS3) is what you want to use. Leaving your commanded afr at stioch is and bastardizing your VE table is a horrible idea.
Old Jul 19, 2011 | 09:27 PM
Gadgetized's Avatar
Yeah, I am running COS3.
Old Jul 19, 2011 | 09:34 PM
Wilde Racing's Avatar
How do I change this text
I view the PE mode as more of a tip-in enrichment as such it is required unless all throttle transitions are smooth and linear...
Old Jul 20, 2011 | 06:47 AM
oldred95's Avatar
That is not the purpose of PE at all. PE is to richen the mix under heavy load to keep the pistons cooler and provide more power. It only engages after a certain % tps. I don't recall what it is set at stock but mine is set at 65%. What you are saying is what the AE TPS or as efi live calls it the stomp compensation does. It gives a quick blast of fuel on a quick throttle opening to stave off any sudden lean condition from all that air rushing in the cylinders. FWIW I can't even feel a difference when mine has gone into PE. On my 95 PE is both a spark table to add timing based on engine speed and the enrichment table. That you can feel really good.
Old Jul 20, 2011 | 07:49 AM
Gadgetized's Avatar
My reasoning behind asking this is because of the drastic change when I hit PE. It is not uncommon at all for me to be running a 13.00/13.5 AFR, go into PE, and the AFR will be 10.00/10.5 on the same cell. Mine is set to engage at 40-45 TPS, and it is extremely noticeable when I hit PE. You can even hear it easily. I just wanted a smooth transition as the kPa increased, and I figured disabling the PE, and correcting it through the VE tables would correct this since I am running an OLSD. I might tinker with this after work to see if it helps. Basically all I should have to do is multiply my VE tables by my PE enrichment to be close to what I need.
Old Jul 20, 2011 | 07:59 AM
JoeyGC5's Avatar
In my cos tunes I don't use pe at all. Just make sure ve is spot on with iat and ect correction tables in and out of boost
Old Jul 20, 2011 | 08:21 AM
smokeshow's Avatar
Mod with training wheels
I tune entirely via the VE table with the Fast fuel injection systems. Then again, it doesn't have PE so there is no option otherwise.
Old Jul 20, 2011 | 08:32 AM
I'm well aware of the many thresholds that must be meet before enabling power enrichment. Also please keep in mind there are suddle differences between efi and hptuners. Hptuners has no table as you describe, we users only have pe and some transient afjustments.
How does efi control pe? Is the table scaled using rpm or map?
Old Jul 20, 2011 | 08:40 AM
smokeshow's Avatar
Can't speak for EFI, but HPT has an enrichment rate coefficient that smooths out the transition.
