GM Factory Remote Start ...
Old Apr 8, 2011 | 03:20 PM
CDN SS's Avatar
Default GM Factory Remote Start ...
2010 Silverado ......only runs for 10 minutes ..any one know if that time can be extended via EFI live ??
Old Apr 8, 2011 | 03:22 PM
Three6GMC's Avatar
I dont think so unless you could get into the bcm but i think that would require a Tech II.
Old Apr 8, 2011 | 07:01 PM
bullygoat's Avatar
No, its hard wired in the BCM. You can extend to an extra ten minutes, it's in your owners manual.
Old Apr 8, 2011 | 08:14 PM
CDN SS's Avatar
Really ......... damm, will go out to truck and check the manual out , Thanks
Old Apr 8, 2011 | 08:33 PM
1994Vmax's Avatar
While the truck is still running just press the lock button again and then start. This will extend the timer for 10 more minutes from whatever point it was at on the countdown. Either that or if it times out just do the lock and start sequence again to restart it. You can only restart, or extend time once giving a max of 20 minutes run time on the remote starter.
Old Apr 8, 2011 | 08:34 PM
CDN SS's Avatar
OK ....got excited there for a moment ........yes I realize you can extend it once its started I was hoping to have it set permanently to run 20 min ....like aftermarket ones ......the extend every time is PIA
So not in the pcm but in the BCM .......
Corvette454l88
Sep 1, 2016 01:24 AM
shawn96gmc
May 17, 2016 04:15 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Ketis
Jul 23, 2015 12:37 PM
