Gauge wiring?
Old May 11, 2013 | 11:53 PM
darnie's Avatar
Default Gauge wiring?
I was wondering if anyone could help me figure out how to wire my gauges. I currently have a PLX dm-100 /wideband gauge hooked up on a toggle switch. I would like to rewire it along with my new autobmeter boost/vaccume (mechanical ) and autometer 100 psi fuel pressure gauge (electrical) gauge so that all 3 will come on when the trucks turned on. Im currently without a computer so its hard for me to search. I just dont wanto get into cutting and splicing and mess something up. Thanks for the help guys.
Old May 12, 2013 | 10:06 AM
darnie's Avatar
So my idea is this.... black wire to battery ground.... white wire to a wire in the dimmer harness for the dash lights. Then try and find a wire off the cigerett lighter for the red wire?
Old May 12, 2013 | 10:16 AM
Atomic's Avatar
I have a gauge for that
Ground wire is fine, but the cig hot wire is always on, so your gauges would be on even with the truck off. Go to autozone and get an "add-a-circuit" and use it in the front fuse panel for something that has power when the key is turned but not when off. This is what I did and I used the instrument panel slot I think.
Old May 12, 2013 | 08:47 PM
darnie's Avatar
Do you by chance have a picture or know whay fuse yoy tapped into? Is it ok to run all 3the gauges off the same one? Btw thanks for the help man i really appricate it.
Old May 12, 2013 | 08:55 PM
Atomic's Avatar
Its the top right one in the inside fuse panel I think. Yea I have like 6 things off of the same one.
Old May 13, 2013 | 01:06 AM
darnie's Avatar
Ok cool in the morning ill check it out and see what one it is. And good to know. What amp fuse are you running in there
Old May 13, 2013 | 01:19 AM
Atomic's Avatar
10a i think
Old May 13, 2013 | 01:24 AM
darnie's Avatar
Ok cool. Ill see about gerting one of those from.vatozone. as far as hooking it up tonthe dimmer harness ypu by chance lnoe what color wire ill need to tap into?
Old May 15, 2013 | 11:43 AM
musclecity85's Avatar
you could relay the red wire off the ignition switch and the white wire off of the dimmer.if you shoot me a pm with your email address i can send u a wiring diagram for your truck
Old May 16, 2013 | 03:08 PM
darnie's Avatar
Well i got it hooked up. Neg/battery. Power from the fuse box top right 10ampon fuse. And the ilumanation wire to the brown/white stripe wore in the dimmer harness
Texas5.3_1251
Mar 5, 2016 08:10 PM
kalikid06
20
Oct 13, 2015 07:37 AM
kalikid06
Sep 13, 2015 05:48 PM
97gmc
22
Sep 8, 2015 10:56 PM
muncie21
Sep 7, 2015 09:55 PM
