engine surge
Old Dec 29, 2007 | 09:59 PM
Truckshop's Avatar
Default engine surge
can anyone help me get my convertor to stop locking and unlocking between 45 and 55 mph. only does it at no load cruise. if i accel it locks and stays locked and slowly quites doing it the closer i get to 60 mph
Old Dec 30, 2007 | 09:12 AM
Mort's Avatar
Do you have tuning software/hardware? The tune can be modified so that it does not happen as often. If not you will need to speak to a tuner, either local or by mail order.
Old Dec 30, 2007 | 09:38 AM
Truckshop's Avatar
yes.hptuners.i read through the stickies and that helped but it is still there. it started after the convertor install.
Old Dec 30, 2007 | 10:38 AM
Mort's Avatar
There are tables for Normal Mode TCC Apply vs %TPS vs Gear and Normal Mode TCC Release Speed (MPH) vs %TPS vs Gear.
Make sure your Apply speed is always higher than your Release speed. If it keeps unlocking at a give %TPS then lower the Release speed a little at a time until it is working the way you want it to.
These are mine for forth gear.
%TPS....4th.....Apply.....Release
0....................45.0......40.0
6....................45.0......40.0
12..................45.0......40.0
18..................45.0......40.0
25..................45.0......40.0
31..................51.0......40.0
37..................55.0......40.0
43..................58.0......40.0
50..................63.0......40.0
56..................68.0......40.0
62..................69.0......45.0
68..................70.0......55.0
75..................70.0......65.0
81..................80.0......75.0
87..................87.0......83.0
93..................87.0......85.0
100................87.0......85.0
Might want to adjust your Cruise Mode tables as well.
Old Dec 30, 2007 | 11:06 AM
Truckshop's Avatar
all of my release speeds are at least 10 mph lower than my apply speeds on all tables. what about the tcc duty cycle tables?
Old Dec 30, 2007 | 11:45 AM
Mort's Avatar
My Max.TCC %Duty Cycle is 99.0 across the table and my Min.TCC %Duty Cycle is 80.0 across the table. A lot of people recommend to set the Min. to 90.0 across the table. I am not sure this will keep it from locking /unlocking but it will definitely firm the lockup and it will feel like a harsh shift at times.
Old Dec 30, 2007 | 12:30 PM
Truckshop's Avatar
gonna try changing that and go drive. be back in a few.
Old Dec 30, 2007 | 12:44 PM
Truckshop's Avatar
that fixed it.THANK YOU!!! i have been fighting this for 6 months. i never looked at the tcc duty cycle settings. my minimums were down in the single digits.
Old Dec 30, 2007 | 02:45 PM
Mort's Avatar
Good to hear that fixed it for you....
superchomper2003
Aug 26, 2015 09:39 AM
DrX
Aug 11, 2015 07:25 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
fillpot
Jul 26, 2015 07:21 PM
85SS/85GN
Jul 22, 2015 12:48 PM
