electrical issue
Old Jan 20, 2013 | 06:40 PM
greasemykey's Avatar
Default electrical issue
so there i was... keys in the ignition about to fire up my 383 stroker. turn the key i hear a click and the dash goes dead and nothing happens. FML!!! i checked the 40 amp ignition fuse and its good. plug it back in and the dash lights up hit the key same click and its dead. what could i be missing? checked the starter relay with the head light and its good. any suggestions?
Old Jan 20, 2013 | 06:54 PM
Koots's Avatar
At this point, my redneck education would have me tapping on the starter solenoid to see if It's sticking. If that doesn't help, then try jumping the terminals on the solenoid to see if it's burned up inside.
Old Jan 20, 2013 | 07:04 PM
Gadgetized's Avatar
Connect the ground from the back of the heads to the body.
Old Jan 20, 2013 | 07:35 PM
the ground is not all the way hooked up. its loose. the starter is new and was tested at orielly and shes good. the bigger issue i am having is why my dash dies and when i unplug the battery or the ignition fuse it turns back on again. ill hook up the ground and report back in a min.
Old Jan 20, 2013 | 07:43 PM
it was the ground strap. i didnt think that one ground being loose would cause all those issues. thank you so much. i was about to pull my hair out.
Old Jan 20, 2013 | 08:26 PM
Gadgetized's Avatar
Glad to hear it is working.
Old Jan 20, 2013 | 08:32 PM
so where are all the grounds supposed to be? i changed the harness and now i have power to the starter but it just clicks. the battery holds 12.4 volts and everything is coming on but just clicks. i think im missing a ground somewhere.
Old Jan 20, 2013 | 08:35 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Sounds like a loose battery cable.
Old Jan 20, 2013 | 08:43 PM
im about to go check the voltage from the battery to the starter if my meter will reach.
Old Jan 20, 2013 | 10:34 PM
im getting 8.4 volts to the starter. i am starting to wonder if my positive battery cable is bad. any thoughts.
