electrical issue
Old Jan 20, 2013 | 10:57 PM
Suburbazine's Avatar
Originally Posted by greasemykey
im getting 8.4 volts to the starter. i am starting to wonder if my positive battery cable is bad. any thoughts.
Happens a lot. Get a small hole in the insulation and corrosion does the rest.
Old Jan 24, 2013 | 11:35 PM
greasemykey's Avatar
it appears that i have made a rookie mistake yet again. i powder coated the alternator bracket and then mounted the ground from the battery to the bracket just like it was from the factory. im thinking this could be why i am having issues with the truck not turning over properly. guess i will have to wait until tomorrow to mount it to my head and see what happens.
Old Jan 25, 2013 | 12:11 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
That could be a problem.
Hope that's all it is!
Old Jan 25, 2013 | 05:21 PM
well that was my issue. moved the negative from the alternator braket to the drivers side cylinder head and she cranks over like a dream.
Old Jan 25, 2013 | 05:41 PM
kretty's Avatar
I was just goona say to check the alt ground... Haha. sucks being an electrician.... I can wire a truck up no problem, but when i have to pull the engine apart....
Old Jan 25, 2013 | 05:46 PM
i am the exact opposite. but i can say that i have spliced the wiring harness using a soldering iron and heat shrink and i did it correctly. so i am not to bad of an electrician. just never thought about the powder coating was a bad idea for the ground. maybe we could open a business. you wire and take it apart. now we just need someone to put it back together. haha
Idryfly5
Sep 2, 2022 08:55 PM
murderedSS
27
Oct 12, 2015 11:13 AM
MA$TER_E
Sep 9, 2015 03:14 PM
the owl
Sep 4, 2015 04:09 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
