EFILive Transmission Shifting
Old Jul 10, 2007 | 06:47 PM
LMK2005's Avatar
Default EFILive Transmission Shifting
Can i setup my transmission shifting so it only goes by RPM? Or does it HAVE to use MPH and RPM?
Old Jul 10, 2007 | 07:58 PM
kbracing96's Avatar
Both conditions have to be meet for the shift to happen. Just make sure your WOT MPH is lower then the RPM and it will shift at the RPM you select.
Old Jul 10, 2007 | 08:00 PM
nightrunner's Avatar
Mr. Obvious
ive heard of people zeroing out the mph so it only uses rpm....
Old Jul 10, 2007 | 09:00 PM
LMK2005's Avatar
Does anyone know if that will work or not??
Old Jul 11, 2007 | 11:18 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I think Dewmanshu is doing it and said it works great. I dont see why it wouldn't.
Just be sure to check your part throttle shift speed as well. There is a setting for 100% TPS, you need to make that 0 as well.
Since both rpm and VSS have to be met in order to command a shift the PCM will rely soley on rpm because the truck will always be above 0mph.
You could always just lower your WOT MPH settings by 30% or so and it wouldn't be an issue.
Old Jul 12, 2007 | 02:39 AM
LMK2005's Avatar
Ok, sounds good. I will try that.
Also, if i want to put my truck in first. I don't want it shifting into 2nd by itself. How can i fix that?
Thanks for the help guys. I'm slowly learning some of this stuff. Hopefully if i have the money this weekend i will be ordering a wide band. Then i can finally start doing some tuning.
Old Jul 12, 2007 | 09:42 PM
LMK2005's Avatar
I zeroed all of the WOT MPH cells. However i still can't put the truck in first and get up to around 30MPH before it shifts by itself.
Its killin me. I need to figure this out soon.
Old Jul 12, 2007 | 10:10 PM
1SlowHoe's Avatar
What does D0913/D0914 read?
Old Jul 13, 2007 | 03:32 AM
LMK2005's Avatar
D0913 = 0
D0914 = 58 Kmh
Old Jul 13, 2007 | 06:29 PM
gmforlife's Avatar
Shift kit i believe is the only thing that will allow the tranny to not do that. When i had my 60E, i did the transgo HD2 shift kit, and after that i could hold 1st gear as long as i wanted. Now that i did my 80E, i have a Superior Shift kit, and just tried it the other day, and it shifts to 2nd by itself. I'll have to look back at my tunes, but i'm 99% sure it's the shift kit.
