EFILive Transmission Shifting
Old Jul 14, 2007 | 01:26 PM
LMK2005's Avatar
I could of swore that i use to be able to do it before i took my trans in to have it built.. But ive changed my tune and stuff since then. Theres gotta be a way.
Old Jul 16, 2007 | 10:44 AM
LMK2005's Avatar
Anyone know if this can be pulled off?
Old Jul 16, 2007 | 10:57 PM
gmforlife's Avatar
I'm pretty sure it's the shift kit bro.
Old Jul 17, 2007 | 12:39 AM
LMK2005's Avatar
If i downshift from 2nd to first at about 20mph... It doesn't shift back to 2nd by itself... It seems like 1st gear only shifts into 2nd by itself based on throttle position.
Old Jul 17, 2007 | 12:45 AM
RandomHero's Avatar
No there's a table in the tune that tells it to shift even when holding it manually in 1st. It's only on the 1-2 shift though.
EDIT-I'm pretty sure it's d0913 in efi live. It's called "Manual hold gear, 1st 1>2 shift speeds. Mine is set on 410 kmh
Old Jul 17, 2007 | 11:33 AM
LMK2005's Avatar
Mine is set on the same thing.... However, right around 25mph it will shift into 2nd.
Here is a copy of my tune if you wanna look and see if i have something else messed up.
File Type: tun
Old Jul 17, 2007 | 01:27 PM
Optimus1's Avatar
I zeroed all of the WOT MPH cells. However i still can't put the truck in first and get up to around 30MPH before it shifts by itself.
Its killin me. I need to figure this out soon.
I think all Chevrolet turbo 400 trannies have that built in to them. My 85 chevy when floored in first will shift (tear asphalt) into 2nd (WOT) 25-30 mph. stock and after the shift kit install ...
Old Jul 17, 2007 | 05:55 PM
gmforlife's Avatar
I actually just compared my old 60E tune to my current 80E tune. The only thing i have noticed, of course i have HPT, but in my normal table of part throttle mph everything looks as it should nothing special there like a 0'd out table, but in the performance mode of that same part throttle the mph is set to 50 mph, where my normal table WAS set to 35. So maybe if you make your MPH in performance table really high, then it will manually hold it, i'm gonna try it this weekend unless anyone else has someplace better to look. In HPT there is not section on Manual Hold or anything, i looked everywhere in the tranny section.
jtphelps289
Sep 29, 2015 12:00 PM
jtphelps289
Sep 1, 2015 08:58 PM
JFortner5
Aug 19, 2015 02:44 PM
lxcoupe
Jul 14, 2015 10:14 PM
