efan issue
Old Jun 22, 2018 | 06:33 PM
jus1975's Avatar
Default efan issue
Heres the situation. Ive had a nelsons efan harness for over a decade. A relay had a slight melt down and damaged the socket. So I noticed ls1fans.com harness was more heavy duty. I purchased it and the reduced pulley and the 2 gauge cable. Wired it the same as the old one. pin 42 and 33 I think. power and ground. plugged the ecm back and battery and the one fans comes on with the truck off. triple checked the wiring and everything is correct. And now my truck will start but wont idle. When I checked continuity on one fan and installed the relay with the fuses removed I had continuity. I switched relays and the same happened. Im not sure but I dont think this is suppose to happen. perhaps the relay sockets are wired incorrectly. maybe. what do you guys think.. Im stuck
Old Jun 22, 2018 | 07:51 PM
ScottyBoy's Avatar
Sounds like something isn't wired correctly. Id contact LS1fans and tell them what's going on, it may be a defective harness.
You should just get an OEM harness pulled from a 05-06 NBS truck. There's a few people who sell them on here, myself included.
Old Jun 23, 2018 | 10:18 PM
jus1975's Avatar
IVe tried emailing LS21fans.com and nobody has replied yet
01Blackerado
77
Jun 22, 2018 09:03 PM
brent5631
Jun 10, 2018 03:44 AM
stoicho315
Feb 3, 2014 08:47 PM
quicksilverado
Aug 7, 2004 10:30 PM
L82gofast
Aug 9, 2003 07:14 AM
