Efan install?
Old Aug 6, 2004 | 09:01 PM
quicksilverado's Avatar
Default Efan install?
For those that have LS1 fans, how did you mount them to the radiator? Is a separate thermostat needed?
Old Aug 6, 2004 | 09:41 PM
MacADaYear's Avatar
I fabricated some hangers out of scrap
Old Aug 6, 2004 | 09:48 PM
Any pics by chance.
Old Aug 7, 2004 | 10:25 PM
abbo7's Avatar
I used those black pull ties and put the foam on between the fans and radiator to keep them from rubbing. Also, do you mean a seperate thermostat to turn the fans on? If so it depends, if you are using a VSC only then you will have to use one, but if you are getting them turned on by the PCM via a tune, then I dont think you will need one.
Old Aug 7, 2004 | 10:30 PM
I've got a harness from Nelson Performance, so they will be activated by the pcm.
creekrat
Aug 2, 2015 01:27 AM
Ammadien
Jul 22, 2015 08:50 PM
ullose272
Jul 19, 2015 04:14 PM
01sierraon22s
Jul 8, 2015 11:26 AM
