Does injector change require retune?
Old May 19, 2018 | 11:09 AM
ACAMS's Avatar
Default Does injector change require retune?
I have a 2003 LQ9 6.0 and read the stock injectors are really too small, so I am thinking of stepping up to 42# injectors ...... will I need to retune my truck?
Old May 19, 2018 | 11:46 AM
Atomic's Avatar
I have a gauge for that
absolutely
Old May 19, 2018 | 12:05 PM
ACAMS's Avatar
Originally Posted by Atomic
absolutely
Can I take that as a maybe not?
I have HP Tuners but don't know what I am doing .... is there something easy to change that I could do?
Old May 19, 2018 | 03:14 PM
Khaos.'s Avatar
Formerly Phaze 2/1/16
Absolutely = yes, you will have it tuned.
Old May 19, 2018 | 03:21 PM
MikeGyver's Avatar
Originally Posted by ACAMS
Can I take that as a maybe not? .......
Old May 19, 2018 | 03:34 PM
MikeGyver's Avatar
1st step is to only buy injectors from a reputable dealer who can supply the correct data for tjose injectors.
Old May 19, 2018 | 04:09 PM
FFDP's Avatar
Do not buy garbage 42's from like siemens deka's or anything ford green tops, you will never find the "right" data.
Old May 19, 2018 | 04:32 PM
ACAMS's Avatar
Where do I put the data .... one place, or several.
Should I replace my injectors, or just be happy until I do exhaust and cam?
I see injectors for sale all the time out of those blower kits that people don't use because they want bigger ..... should I avoid those for sure?
I guess I need to hurry up and learn how to tune!!!!!
Old May 19, 2018 | 04:37 PM
FFDP's Avatar
Injector flow, short pulse adder, offset vs volts etc etc, those are tables you change with the data given.
If the truck is stock, the injectors are fine as they support stock 6.0 power outputs. When you jump over to exhaust and a cam, then upgrade them. If you want injectors that are drop and go injectors with data you can pull from a stock vehicle, go with 8.1 Vortec injectors. They are rated at 31lb/hr compared to the 25lb/hr you have now. They are large enough to give you the headroom you need.
Everything still has to be tuned. From changing the injector data then to fully re-calibrating the MAF curve, the VE table and adjusting other odds and ends as required.
Old May 19, 2018 | 04:58 PM
ACAMS's Avatar
Will buying a wideband help me tune it, or will it complicate things?
I am 60 and must be stupid because I haven't been able to grasp this tuning stuff yet.
I am also a broke tightwad and don't want to pay $500 and up for tuning school .... what do you suggest, sell my HP Pro and pay somebody to dyno tune my tuck, or is there a tuner somewhere that will charge a fair price to help me with my tune?
Before I bought the HP Tuner I had several offers for a mail order tune ..... whould that be an option with a cam, exhaust and injector upgrade?
