Disable adaptive shift learning after Shift Kit Install
Old Jan 23, 2008 | 07:30 PM
BlackGMC's Avatar
Resident Retard
Default Disable adaptive shift learning after Shift Kit Install
I placed my order with FLT for a shift kit and other goodies. I allready have both servos, Soooooooo I have read that you need to disable adaptive shift learning after you install a shift kit, is this true? I read that you zero out your shift times, which disables the learning. I have also read that if you don't it will cause your shifts to soften over time. Has anyone else done this?
Old Jan 23, 2008 | 07:41 PM
laynlow77's Avatar
just looked at my tune and thats how mine are. justin (blackbear) did it so id assume its right.
Old Jan 23, 2008 | 07:45 PM
BlackGMC's Avatar
Resident Retard
Thanks cheif! Just making sure
Is the table completely zeroed?
Old Jan 23, 2008 | 08:29 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
You may want to post this on EFIL's forum, and see what responses you get. I haven't done that to my tunes, and can't say that a pro tuner would do so.
Old Jan 23, 2008 | 08:31 PM
BlackGMC's Avatar
Resident Retard
Its posted on EFI Live forum. No responses over there yet...
Old Jan 23, 2008 | 08:37 PM
Wilde Racing's Avatar
How do I change this text
In the 01-02 pcm there is an "pressures" tab that the adptive crap can be disabled, but I'm not sure if efi is set-up the same....
Old Jan 23, 2008 | 08:50 PM
BlackGMC's Avatar
Resident Retard
Found these threads
Originally Posted by wait4me
the Shift speed on that table is just telling the trans to try to hit that time during a shift. The shorter the better, but the firmer the shift will be.
If you 0 out that table, then you are just shutting off the adaptive trans learning system. It dont mean you are commanding a 0 second shift..
People with shiftkits are supposed to remove the adaptive shift system. So zeroing out that table is correct.
If not removed with a shiftkit, then the computer sees that the trans is shifting too fast and it will pull pressure " via the adaptive shift system " and try to slow the shifts back down.
That is why guys with a shift kit or modded tranny see the transmission shift really good for a couple miles when they first plug on thier battery. then the trans slowly starts backing down....
Old Jan 23, 2008 | 09:05 PM
dc_justin's Avatar
Hello Dave
Zero them. Then, what you see via the force motor current, base pressure and pressure temperature modifier tables is what you get.
Old Jan 23, 2008 | 09:17 PM
BlackGMC's Avatar
Resident Retard
Thanks Justin, So after I zero out the tables I can fine tune the base pressures to my liking?
Is there a PID to measure transmission slip. I think I read somewhere that you log engine output vs transmission input, something like that but I can't find the thread....
Old Jan 24, 2008 | 08:31 AM
HD6.0l's Avatar
Banned
Zero is it .(Jesse @ Wait4me Performance helped with mine , thanks Jesse .)
Been running a TransGo kit , and zeroed shift times , after the kit you don't really need to do much by way of line pressure the kit does that for you .
If done correctly you probably want want to mess with the trans in the PCM , start with stock settings , except the shift time , that is if you have raised anything for the trans in the PCM (line pressure) .
LCHEE
Oct 24, 2020 04:10 PM
fastjweb
Aug 15, 2015 10:47 AM
Ammadien
Jul 22, 2015 08:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
1987cut
Jul 12, 2015 09:59 PM
