Climate control issue (hope this is the right forum)...
Old Feb 11, 2009 | 12:47 PM
AV8R27's Avatar
Question Climate control issue (hope this is the right forum)...
Short story...short, I have no temp control on the passenger side...it's always HOT. I know there's a little motor for each side that controls heat/cold...and I have control on the driver side. I know which motor it is, I can hear it run (driver). I found the motor behind the dash for pass. control as well...when cycled between hot/cold...this motor isn't moving. Really don't imagine it's an ICC problem...so I'm really thinking it's the module itself for the control (switches), or the motor that controls this flue (sp?). Don't imagine it would be that motor for the simple sake that the driver side would be cycled more in its life that the passenger side...but hey, electronics do some crazy stuff. Any insight? Thanks...
Old Feb 11, 2009 | 05:56 PM
04Silverado5.3's Avatar
It is usually the actuator (motor) for the passenger side blend door that goes bad. I remember that there was also a reflash (software upgrade) for the HVAC control module. The control module would try to overdrive the actuator beyond its stops and eventually it burns up the actuator.
Old Feb 13, 2009 | 11:19 PM
Wilde Racing's Avatar
How do I change this text
Nice first post...
Welcome to the site you two....
Old Feb 26, 2009 | 03:59 PM
white lightning SS's Avatar
It is always the actuator. Pull the dash pad and some of thos brackets on the RH side. Move the defroster duct up and ahead and you can get to the 5.5 screws with a snap-on 5.5 1/4 inch universal socket. A dealer or side shop will probably charge around 3 hours labor to replace it.
zblee
63
Jun 10, 2023 01:25 PM
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Sep 7, 2015 05:50 PM
Austino
Jul 30, 2015 03:28 PM
