Cleaning fuel injectors 06 silvy 6.0
Old Oct 4, 2011 | 06:42 PM
pmgm's Avatar
Default Cleaning fuel injectors 06 silvy 6.0
Hello, I wanted to know what is the best way to clean fuel injectors. My engine light is on and at first I had a po300 code. Thats gone after spark splugs and wires now I have the po200 code. Using the a Snapon scanner showed me the misfire history and how the truck is running now. This is how they look now.
Misfire cycles.....
CYL 1____20___ MISS HIST 135643
CYL 2____0 ___ 21
CYL 3____0____ 335
CYL 4____0____ 16
CYL 5____0____ 60
CYL 6____0____ 54
CYL 7____0____ 0
CYL 8____1____ 3817
My question is should I get them all cleaned or replace the ones that are really bad.I just pulled the rails and injectors and instead of switching them around and puting it back together I thought I would ask.....
Please tell me what you think I should do.... #1 and 8 seem to be where the problems are....
Thanks
Pernell
Old Oct 4, 2011 | 07:15 PM
Atomic's Avatar
I have a gauge for that
I would switch them around first, just to confirm...
Old Oct 4, 2011 | 07:42 PM
low2001gmc's Avatar
easiest and cheapest way is buying and using chevron synthethic fuel injection cleaner.
one time a truck i was about to trade in was misfiring so bad and i called up my best friend who worked at a dealership for advice. he said go buy some chevron synthethic fuel injection cleaner in a black bottle and pour it in. if misfiring dont go away in a block or two, youre gonna have to spend on a tune up. he said its what we use at the dealership to clean fuel injectors, we pour it in, we drive the vehicles several blocks and come park it, have customers wait in the lobby for an hour so we can charge them the hourly rate, call them up and they are ready to go. true story.
after a block, misfiring gone. i swear by it and wont misspend my money on any other fuel injector cleaner. give it try. mix it up good with your gas. let us know results, rob
Old Oct 5, 2011 | 04:27 PM
pmgm's Avatar
I will do that first... If the miss moves with the injector would you clean or replace them?
Thanks
I might pick up a bottle just in case... Im just trying to get this taken care of while we still have good weather...
Thanks
Old Oct 5, 2011 | 04:42 PM
Atomic's Avatar
Depends if I wanted to upgrade anyway...if not I would try the cleaner, but stock injectors are pretty cheap anyway. If I wanted to upgrade I wouldnt bother with the cleaner.
Old Oct 5, 2011 | 04:50 PM
pmgm's Avatar
Truck is stock no mods... So I wouldn't need to upgrade rite now...I will be doing some mods in the spring... I just want to fix the problem rite now..
Old Oct 5, 2011 | 09:25 PM
pmgm's Avatar
Ok... Now im getting pissed... I switched the injectors..
#1 to #3
#8 to #7
The miss did not move. It's still in the same cylinders, What should I check next?
Old Oct 5, 2011 | 09:38 PM
YodiBrodi's Avatar
move the coils for 1 and 8, check the connectors at 1 and 8 for coils and injectors. there could be broken or loose connections in there. make sure your plug wires are on all the way and in good shape
Old Oct 6, 2011 | 04:24 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Check your injector wiring connections. I had a similar issue and I squeezed the connections together to make a firmer fit on the injector and it was fixed.
Old Oct 8, 2011 | 07:27 PM
pmgm's Avatar
Ok.. I will try that...
Thanks
