Cleaning fuel injectors 06 silvy 6.0
Hello, I wanted to know what is the best way to clean fuel injectors. My engine light is on and at first I had a po300 code. Thats gone after spark splugs and wires now I have the po200 code. Using the a Snapon scanner showed me the misfire history and how the truck is running now. This is how they look now.
Misfire cycles..... CYL 1____20___ MISS HIST 135643 CYL 2____0 ___ 21 CYL 3____0____ 335 CYL 4____0____ 16 CYL 5____0____ 60 CYL 6____0____ 54 CYL 7____0____ 0 CYL 8____1____ 3817 My question is should I get them all cleaned or replace the ones that are really bad.I just pulled the rails and injectors and instead of switching them around and puting it back together I thought I would ask..... Please tell me what you think I should do.... #1 and 8 seem to be where the problems are.... Thanks Pernell |
I would switch them around first, just to confirm...
easiest and cheapest way is buying and using chevron synthethic fuel injection cleaner.
one time a truck i was about to trade in was misfiring so bad and i called up my best friend who worked at a dealership for advice. he said go buy some chevron synthethic fuel injection cleaner in a black bottle and pour it in. if misfiring dont go away in a block or two, youre gonna have to spend on a tune up. he said its what we use at the dealership to clean fuel injectors, we pour it in, we drive the vehicles several blocks and come park it, have customers wait in the lobby for an hour so we can charge them the hourly rate, call them up and they are ready to go. true story. after a block, misfiring gone. i swear by it and wont misspend my money on any other fuel injector cleaner. give it try. mix it up good with your gas. let us know results, rob :) |
Originally Posted by Atomic
(Post 4786223)
Thanks
Originally Posted by low2001gmc
(Post 4786233)
one time a truck i was about to trade in was misfiring so bad and i called up my best friend who worked at a dealership for advice. he said go buy some chevron synthethic fuel injection cleaner in a black bottle and pour it in. if misfiring dont go away in a block or two, youre gonna have to spend on a tune up. he said its what we use at the dealership to clean fuel injectors, we pour it in, we drive the vehicles several blocks and come park it, have customers wait in the lobby for an hour so we can charge them the hourly rate, call them up and they are ready to go. true story. after a block, misfiring gone. i swear by it and wont misspend my money on any other fuel injector cleaner. give it try. mix it up good with your gas. let us know results, rob :) Thanks |
Depends if I wanted to upgrade anyway...if not I would try the cleaner, but stock injectors are pretty cheap anyway. If I wanted to upgrade I wouldnt bother with the cleaner.
Truck is stock no mods... So I wouldn't need to upgrade rite now...I will be doing some mods in the spring... I just want to fix the problem rite now..
Ok... Now im getting pissed... I switched the injectors..
#1 to #3 #8 to #7 The miss did not move. It's still in the same cylinders, What should I check next? |
move the coils for 1 and 8, check the connectors at 1 and 8 for coils and injectors. there could be broken or loose connections in there. make sure your plug wires are on all the way and in good shape
Check your injector wiring connections. I had a similar issue and I squeezed the connections together to make a firmer fit on the injector and it was fixed.
Originally Posted by 1SlowHoe
(Post 4787195)
Thanks |
