Cant get engine running
Old Sep 5, 2010 | 11:28 AM
SSZ's Avatar
SSZ
Default Cant get engine running
OK so i just dropped in a 5.3 into my 80 Z28. I was told that the computer has been programmed to run without the emissions. Attempted to start the engine and just cranks. IT has spark. No injector pulse. Checked for codes with my shitty code reader and it has a code 1336. Will this shut down injector pulse? According to what i have read you have to have the engine running in order to do the crank relearn procedure. Any other ideas as to why i dont have an injector pulse? Also i dont have any O2s on yet but again i dont think this would stop the injectors from operating. There is good fuel pressure to the injectors and injectors have power going to them.
ALso, put some raw fuel into the intake and engine did run till the fuel was gone. Any ideas
Old Sep 5, 2010 | 01:29 PM
sixltrbtr's Avatar
This code shouldn't disable the injectors. You need to make sure you have power to one wire at each injector when the key is on. The computer controls the injector with the ground. If you don't have the power it could be a fuse, ignition switch or wiring problem. If you have the power and aren't getting the ground signal from the computer it could be a computer ground or wiring or something like that. Could also be a bad computer.
Old Sep 5, 2010 | 01:38 PM
Grumpy5.3's Avatar
like said above, it is likely a ground problem. check and double check ALL of your grounds to the pcm.
Old Sep 5, 2010 | 02:09 PM
SSZ's Avatar
SSZ
Gotta be a ground issue. All injectors have power to them. Will have a look. Thanks guys.
Old Sep 5, 2010 | 10:19 PM
sixltrbtr's Avatar
After rereading your original post I'm starting to think you could have a theft problem. If the computer detects a theft it kills the injectors. No code saying theft detected?
Old Sep 6, 2010 | 02:20 PM
SSZ's Avatar
SSZ
No. no code for theft system.
stealthperf
34
Feb 14, 2016 11:35 AM
Noah Burns
Sep 7, 2015 05:50 PM
atxlt
Jul 20, 2015 11:06 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Mzay
Jul 6, 2015 11:03 PM
