Can I modify Active Fuel Mgt. with EFI Live?
LS1 Tech Administrator
I have a 2007 Suburban. I also have EFI Live with the V2 programmer and all the latest updates. Am I able to modify the Active Fuel Mgt. portion of my program? It's very difficult for the motor to stay in 4 cylinder mod unless I'm coasting or going downhill. Can I make it stay in 4 cylinder mode longer with EFI Live?
Originally Posted by foff667
We've had roughly 3 dozen DOD enable/disable parameters for quite a while now.
There are alot of different variables that can keep you out of DOD mode...there is a max in dod threshold, rpm min/max, vac min/max, tps min/max, etc that all need to be met & kept in check.
Thanks,
Bob
PS: Its Bill
Thanks,
Bob
PS: Its Bill
Sorry about the name flub Bill
I understand about meeting all the other thresholds you mentioned. Other than a few changes to the TPS parameters, it looks like it all comes down to manipulating the vac min/max tables. This is where I was looking for your comments on which way to skew the vac tables to allow AFM mode to become engaged at higher kPa readings and stay there. Thanks.
Raggedz71
Jul 29, 2016 10:20 AM
kr1s
Aug 24, 2015 05:34 PM
GMCtrk
Jul 17, 2015 06:39 PM
