Anyone w/ EFIlive have a tune that I can go off of?
Old Sep 4, 2006 | 07:21 PM
foxySS's Avatar
Default Anyone w/ EFIlive have a tune that I can go off of?
I just got EFIlive FlashScan and I'm really confused. Just wondering if anyone with a radix or whipple with similar mods as mine is willing to give me a copy of their tune for a base to go off of?
For some reason it's not reading my PCMforLess tune. I'm thinking that Bryan probably locked it.
Thanks,
Chris
Old Sep 4, 2006 | 07:48 PM
1SlowHoe's Avatar
Destroyer of Transmissions
PM me your email and I will send you a couple or check out this site:
http://www.holdencrazy.com/EFILive/
You can pick from stock files as well as modified ones.
Old Sep 5, 2006 | 04:12 AM
foxySS's Avatar
Sorry, I should have mentioned I already checked that site. Just wondering what else is out there or if there's anything a little closer to my setup.
Old Sep 5, 2006 | 04:40 PM
dc_justin's Avatar
Hello Dave
Shoot me a PM, I'll gladly walk you through some things.
I'd send you one of my tunes, but I'm running a custom OS which wouldn't quite apply to you.
If you'd like, you can shoot me your current tune to jgadberry AT gmail DOT com, and I'll take a look at it for you. Also, send a couple of logs with it too.
Old Sep 5, 2006 | 04:47 PM
Tan327's Avatar
I'm not sure if this helps any, but Bryan doesn't lock his PCM's so you can rule that out.
Old Sep 5, 2006 | 04:53 PM
dc_justin's Avatar
Hello Dave
Originally Posted by Tan327
I'm not sure if this helps any, but Bryan does lock his PCM's so you can rule that out.
Must be a newish thing then, as mine wasn't locked (thankfully) when I purchased it last summer.
Foxy, I highly suggest logging your truck and slowly rolling into the throttle to see what point you switch from closed loop to open loop... EG, when the O2 sensors stop switching and flatline at the upper end of the scale... Lemme know what your TP% and MAP values are at that point if you could.
Old Sep 5, 2006 | 09:09 PM
Tan327's Avatar
Woah that was a typo! I meant he doesn't lock his PCM's..
Old Sep 5, 2006 | 09:10 PM
dc_justin's Avatar
Hello Dave
Heh, small typo completely changes your message.
Old Sep 5, 2006 | 09:16 PM
Tan327's Avatar
Yes sir, sorry about that!
Old Sep 5, 2006 | 09:18 PM
dc_justin's Avatar
Hello Dave
Can you connect to the PCM at all? If not, check your cigarette lighter fuse under the hood. I've seen a number of these things blown, even on brand new trucks.
