Anyone here know about the A/C tables?
Old Apr 21, 2012 | 08:58 PM
oakley6575's Avatar
Default Anyone here know about the A/C tables?
Well boys, it hit 100 degrees here today in Las Vegas. So I guess that means it's summer time. I tried getting a response over on HPT forum about the A/C tables and how each table effects A/C operation. No answer so far. I did some searching on HPT and google but couldn't come up with any info. So I will bring it up here and see if anyone is knowledgable in this area. Below is my post on HPT:
Can someone explain the different tables that control the air conditions system in the pcm. Inertia tq, ramp in/out, spark retard, ect. This might be a stupid question but I'm having a hard time understanding what these tables tell the pcm to do.
Is the inertia tq table something that tells the pcm how much tq the a/c clutch will take to engage? So if your rpm drops when engaging, the numbers in the inertia tables should be increased?
I don't understand what ramp in/out is at all.
Why would the pcm want to retard spark advance when the clutch engages? Thanks guys
Old Apr 21, 2012 | 09:26 PM
mcfarlnd's Avatar
Un-Registered User
It retards the spark because it is putting a load on the motor. I never messed with any tables for a/c aside from engage and disengage RPM.
Old Apr 21, 2012 | 09:36 PM
BlackGMC's Avatar
Resident Retard
The spark ones pull timing when the clutch engages...
The Torque loss helps with airflow. It adds addition air flow when the AC clutch is engaged.. Basically it adds on top of your Desired Airflow/Running Airflow. The way you set it is, dial in our Desired Airflow like normal with the AC off, then after you have it dialed in you can do 1 of 2 things... turn on your ac and log your desired airflow again, note the difference, then multiply the AC TQ loss or AC TQ Loss IAT table by that percentage, or what i did was just multiply the AC TQ Loss IAT by 10%, then drove it, it still surged so i added another 10%, and drove it, basically i repeated this process 5 times increasing that table ~50%.
Old Apr 21, 2012 | 09:38 PM
BlackGMC's Avatar
Resident Retard
So basically if your truck is surging with the AC on only mess with the tables i mentioned
Old Apr 22, 2012 | 10:51 AM
CalEditor@PCMCalibrators's Avatar
FormerVendor
How does the PCM control idle in steps? (1st, 2nd, 3rd, 4th)
If the first thing that the PCM does to correct idle is increase or decrease timing because it can dp this quicker than moving the IAC on a DBC then why would it retard the timing when the AC kicks on?
Old Apr 22, 2012 | 10:37 PM
oakley6575's Avatar
Russ K told me to zero that table out. Is that something you disagree with?
Old Apr 22, 2012 | 10:51 PM
oakley6575's Avatar
I guess I don't understand what table you're refering to. What table are you adding airflow to?
Old Apr 25, 2012 | 12:46 AM
oakley6575's Avatar
Anyone?
Vortec350ss
Jan 12, 2016 10:36 PM
FormulaZR
Sep 14, 2015 05:23 PM
Hpinnovate
Sep 4, 2015 02:28 AM
