Anyone else have rich idle issues with 42/44lb 8.1L marine injectors
Old Nov 6, 2011 | 07:53 PM
budhayes3's Avatar
PT's Slowest Truck
What, was Ben messing with your tune?
Hey Corey, I'm curious as to what kind of IDC you're seeing with those injectors and your setup? Thanks.
Old Nov 6, 2011 | 08:01 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by Atomic
BEN factor?
Actual/Expected=BEN
For example:
Actual AFR/Commanded AFR = BEN
14.00/14.68= 0.95
If you were tuning VE, you could multiply that cell by .95, thus lowering it thus making it leaner...
Another example LTFT:
1 + (({SAE.LONGFT1} + {SAE.LONGFT2})/200) = BEN. I made this custom PID to average both banks and put them in a BEN format (1.05, 0.95, etc...
Here is one for the STFT
1 + (({SAE.SHRTFT1} + {SAE.SHRTFT2})/200)
Here is one to see the difference between VE and MAF to see if your tuned properly..
GM.CYLAIR_DMA}/{GM.DYNCYLAIR_DMA
Old Nov 6, 2011 | 08:05 PM
BlackGMC's Avatar
Resident Retard
hmmm, i have not checked it in awhile, but upper 60s lower 70s somewhere around there... I think...
Old Nov 6, 2011 | 08:47 PM
dlt76028's Avatar
Originally Posted by BlackGMC
Well i spent the day dicking with the truck. I took off my ypipe and put a
Flat file to all the vbands, they were not completely flat from the black on the the passenger side was leaking a little bit. I ditched the TR6s and put in some new TR5s. I recalibrated my wideband too.
Next i started over with the tune. I used a 2004 8.1L injector setting except for the flow rate. I adjusted it for the 42lbers.
Redid the VE and MAF and the problem was still there on wierd occassions. So i got to digging. I made a map of the throttle cracker table with the BEN factor fromy LTFTs. LOW AND BEHOLD that was the problem. I had WAY to much in some areas and not enough in others. Made some adjustments and it is doing tons better.
thats alot of work, the wife out of town?
Old Nov 6, 2011 | 08:50 PM
BlackGMC's Avatar
Resident Retard
Nope but she was doing school stuff all weekend. Yester i installed a whole home water filter and water softener. Busy busy.
Old Nov 7, 2011 | 11:13 AM
BlackGMC's Avatar
Resident Retard
Well ****. It is back. Same issue with some new issues. Trims are negative with truck ingear below 1200rpm. Something new the trims go way positive when let off the throttle crusing around 60mph. I am thinking it is throttle cracker in the upper MPH may e running airflow at lower rpms. Such a pain in the ***
Old Nov 7, 2011 | 11:18 AM
dlt76028's Avatar
you should just drive your truck and not pay attention to the gauges.
Old Nov 7, 2011 | 11:30 AM
f4tal's Avatar
My brain hurts...
Old Nov 7, 2011 | 12:14 PM
2007chevy5.3l's Avatar
**** all that bullshit
Old Nov 7, 2011 | 12:16 PM
Atomic's Avatar
I have a gauge for that
ya know....whenever I have a tune that is just not behaving no matter what I do to it I put the relavent stuff back to stock and start over...
