Any interest in bench tuning harnesses?
Old Oct 9, 2018 | 06:29 PM
ezdaar's Avatar
Default Any interest in bench tuning harnesses?
As topic says.
i will be building a few soon, could easily make more for you guys.
Old Oct 9, 2018 | 10:33 PM
Last Call's Avatar
TOTM: January 2007
Originally Posted by ezdaar
As topic says.
What controllers are you making them for?
Old Oct 10, 2018 | 12:20 PM
1FastBrick's Avatar
Custm2500's Rude Friend
If your doing 1 type of controller It may be worthwhile to save a few bucks and do it yourself. I like to Dabble with different projects and sometimes need different ECU connectors.
I started with the EFI Connection Hobby series set back in the day and recently upgraded to the Bench force series. I have several adapters for ECU/PCM, Body control module and a cluster harness so I can work with them out of the vehicle. I am kind of sad that they discontinued the hobby series as I felt it was great option for the DIY person.
The Bench force series is very robust but the cost is not really consusive with a DIY person.
Old Oct 10, 2018 | 07:48 PM
ezdaar's Avatar
I will be building the harness on the right.
99-03 ecu
but i can make any year, its just a matter of pinning the blue plug correctly.
every part will be new and wed in tekflex
Old Oct 10, 2018 | 11:25 PM
99-03 ecu
If it works on 99-03 Blue/Red it will work on 03-07 Blue/Green.
Old Oct 10, 2018 | 11:51 PM
1FastBrick's Avatar
99-03 ecu
Yes that's the Hobby style they used to offer. It worked great for years. But they don't support it any more. So when I had to buy new ECU connectors, I needed an adapter.
I sold it to a friend who still uses it and make his own connectors for his stuff. I sent some of the old connectors I had out and they updated them with the new plug for the Bench force adapter.
If you know what your looking for, you can buy all the plugs and pins through mouser cheaply. It wouldnt surprise me if they bought in bulk from them as well.
FWIW, The 99-07 classic trucks are pined the same for communication and power on the Blue side.
randeez
39
Feb 19, 2023 04:44 PM
blackedoutchevy22
Sep 27, 2019 12:15 PM
00pooterSS
37
Sep 20, 2018 09:27 PM
