AFR Erratic at Steady Cruise Throttle
Old Nov 1, 2008 | 04:17 PM
Bad Boyz Racing's Avatar
Default AFR Erratic at Steady Cruise Throttle
My a/f is fine WOT and PT but just cruising around but sometimes the a/f pegs out lean 17/1 at steady throttle in tc lock. If I blip the throttle it will return to normal but soon go way lean again. After a while it'll run 13's rich and then stoich again. All this at steady cruising throttle. All this started the day after the 4L80E swap. The only thing that changed other then the wiring was the drivers side exhaust had to be re-routed do to the deep pan on the 4L80E. Having the truck dyno tuned next weekend. Hopefully they will have some answers.
Old Nov 1, 2008 | 05:46 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
lol, mine used to do the same thing...started right after I did long tubes, damn that AFR gauge would bug me. I learned to ignore it. It doesn't seem to do it anymore, since I went MAFless.
Old Apr 6, 2009 | 11:39 AM
Coban's Avatar
Did you ever figure this one out? I am having the same problem...
Old Apr 6, 2009 | 12:19 PM
norris_83's Avatar
can u post up a scanner log?
Old Apr 6, 2009 | 03:18 PM
Coban's Avatar
Yea, I'll do it tonight or tomorrow morning. It always does it in the morning.
Old Apr 6, 2009 | 03:29 PM
BlackGMC's Avatar
Resident Retard
How old are you factory O2 sensors? I would bet if you logged them one or both are being lazy...
Old Apr 10, 2009 | 09:43 AM
krambo's Avatar
First get that wideband hooked up to your scanner and do some Ve tuning with % AFR error (not by trims). Looking at your Ve LTFT histo, it appears a little off. I would then do the same for your MAF (using your wideband).
Did you by any chance have the A/C or the defroster on during these scans?
Old Apr 10, 2009 | 10:19 AM
Coban's Avatar
I did have the A/C on. Is that was the timing dips are? I didn't think about that one.
I'll see if I can wire that wide band into my interface. I don't have the EIO version of HPTuners.
Old Apr 12, 2009 | 08:20 AM
krambo's Avatar
More than likely.
Using the wideband is pretty much the only way you are going to safely tune the upper end of your Ve and MAF (provided you are not SD). A steady state dyno tuning session wil make short work of it for sure. Keep us posted.
Choda
Jun 5, 2025 06:43 PM
99bluefirebird
Sep 17, 2015 08:05 PM
Rockrz
Sep 13, 2015 12:22 AM
2500ZL1
Sep 12, 2015 03:50 PM
