99-00 02 sensor issue upstream
Old Jan 16, 2014 | 05:41 PM
ls1prayer's Avatar
Default 99-00 02 sensor issue upstream
Ok I am chasing down problems on my truck And i simply need to know which wire needs to go where.
on truck bank 2 sensor 1 factory wiring harness side
black
tan
purple
pink
on my new bosch plug was plug and play but guys before me hacked it
new plug
gray
blk
white
white
Anyone know which goes to which. I looked at my other truck and it seems to have a different setup
any help would be amazing
Old Jan 16, 2014 | 06:14 PM
Suburbazine's Avatar
Well, here's the connector that's supposed to be there. I'm sure you can work out what wire goes to what pin.
However, you need to get a new connector for the chopped up wires. The Bosch sensor is oxygen referenced by the wires, cutting/splicing them removes it's ability to "breathe" so to speak.
Old Jan 16, 2014 | 06:24 PM
ls1prayer's Avatar
oh snap so the older chevys like mine have same 02 sensor and connection for down and upstream ?
Old Jan 16, 2014 | 07:20 PM
It can have either a 4-flat or a square on the upstream. The square is more common in the 01-02's.
Whatever you replace it with won't matter, though. Just don't splice the HO2S to the harness!
Code:
If the HO2S pigtail wiring, connector, or terminal are damaged,
 replace the entire HO2S assembly. Do not attempt to repair the
 wiring, the  connector, or the terminals. In order for the sensor
 to function properly, the sensor must be provided with a clean
 air reference. This clean air reference is obtained by way of the
 HO2S wires. Any attempt to repair the wires, connectors, or terminals
 could result in the obstruction of the air reference. Any attempt to
 repair the wires, connectors, or terminals could degrade
HO2S performance.
Old Jan 16, 2014 | 07:48 PM
ls1prayer's Avatar
ooh holy batman this cant be good. is there another harness I can buy somewhere? also The guy who had the truck before me spliced the original plug up and extended it for some unkown reason. So I am at a stand still trying to see if I can splice 1 time into it from a bosch 13026
Old Jan 17, 2014 | 04:14 AM
If you have to modify anything related to the oxygen sensor itself (including the plug/pigtail) don't do it. Go to a dealership and tell them you need both front bank oxygen sensor pigtails. You can splice pigtails into the PCM side harness, just not the sensor side wires.
Old Jan 17, 2014 | 07:39 AM
ls1prayer's Avatar
Oh ok thanks. And does the down stream sensors work up stream also Considering they have same plug?
Old Jan 17, 2014 | 01:52 PM
Same plug, different sensors. The rear sensors are also more expensive, as they're designed to operate on a much slower cycle at lower temperatures. In a normally operating catalytic system, the rear sensors cycle about once for every seven times the front sensors cycle.
Old Jan 17, 2014 | 02:33 PM
ls1prayer's Avatar
Your the man thanks
zblee
63
Jun 10, 2023 01:25 PM
smokeshow
Aug 23, 2015 08:23 PM
Fast86z
Aug 23, 2015 12:35 AM
nrmskate
Aug 12, 2015 09:17 PM
05GMC4.8
Aug 7, 2015 09:55 PM
