90mm TB and X link issue
Old Apr 29, 2014 | 03:42 PM
  #61
darkirish63's Avatar
Nothing...still starting with no codes. Could the last ones that flashed have been "leftovers" from prior to me re-wiring the TB harness?
Old Apr 29, 2014 | 04:47 PM
  #62
DrX's Avatar
DrX
Was it setting the codes before when starting, or while driving?
Old Apr 29, 2014 | 05:17 PM
  #63
The first few times it happened it was while I was driving but since then just on start-up when hot. Didn't do it at all today.
Old Apr 29, 2014 | 09:22 PM
  #64
DrX's Avatar
DrX
Any difference in the ohm tests after tugging on the wires coming out of the box?
Old May 2, 2014 | 08:56 PM
  #65
Sorry...been out of town. I'll try it in the morning.
Old May 4, 2014 | 02:00 PM
  #66
No difference when tugging on the wires - but I've not been tossing any codes since swapping out the old X-link for the 4.0. Had to be it...
Old May 4, 2014 | 08:41 PM
  #67
2doorfury's Avatar
Man, I really hope the modification works for me. If it doesn't work, my only option is to buy a adaptor for my 4 bolt intake and put the factory 3 bolt TB back on. It'll be a huge waist of a intake, but at least it'll run
Old May 7, 2014 | 09:52 PM
  #68
Courtntan's Avatar
I don't know if this helps but I put one on my truck and it worked perfect, then I changed the Throttle Area Scaler table to the .0158 that was recommended in the instructions and I lost any throttle input. I changed my tune back to stock values and had my throttle back. My engine is also a 2003. Just another place to look, I know it caused a similar condition with mine.
Old May 8, 2014 | 02:49 AM
  #69
2doorfury's Avatar
Did yours throw a code? If it did, could you clear it and get it working?
Old May 8, 2014 | 09:31 PM
  #70
Courtntan's Avatar
I never checked it for codes. I threw the new tune in, backed out of my lane way without touching the gas pedal, put it in drive and coasted downhill to a stop sign because it had no throttle at all. I shut it off, threw the old tune with the stock settings in and it worked perfect again. The only thing I notice is a very slight delay in throttle response.
