90mm TB and X link issue
Just installed a edelbrock pro flo intake and 90mm LS3 throttle body with the x link. The x link is a month old, brand new and is the very newest version. The problem im having is no throttle response. When key turned in, the TB will flutter slightly, then go closed. When trying to start, it fires up for a second then dies. Pressing accelerator peddle doesn't do anything. But since it does have movement when key is turned on, that leads me to think it is getting signal. I could be wrong tho. Any help would be appreciated
Any trigger wires tapped into the throttle wiring?
http://torquerush.com/GM%20Electroni...leshooting.pdf
Everything is hooked up right, grounds are all on, all plugs are connected.. I've also added ev6 injectors with the adaptors. The intake, TB and injectors are all new to engine.
Any other 2003-2007(classic) trucks around that you can plug the TB and X-Link into to see if it operates?
