5.3 to 6.0 and now trucks childproof HELP lol
I switched back to my original pcm that was dyno tuned for the 5.3 and trucks works perfect, i cant believe it, i hit some wot runs and air fuel is fine, can anyone explain me how this is possible? Is it bad to drive like this?
The TAC module that runs your DBW throttle body was changed to a different one in 06. If you use an 06 PCM, you need the 06 TAC module and pedal....... 03-05 used the same throughout the years. I wouldnt be too crazy on it till its tuned. Glad it worked out.
No. They changed the TAC and Pedal. Not the TB. When they changed the TAC and pedal, the operating system and wiring is a little different. Changing the TB doesn't help.
