4l80segment swap converter lock on lift of gas
Old Dec 2, 2013 | 01:37 AM
05gmcsierra's Avatar
Default 4l80segment swap converter lock on lift of gas
has anyone figured out i theres a method to keep converter locked when u lift after converter has been locked when tuning with efi live? i know u can fix that issue with hp tuners i usually do it that way but i hate buying credits for hp when i have efi live. when doing a segment swap has efi live found a way to keep converter locked on hwy? thanks in advance..
Old Dec 2, 2013 | 09:59 AM
Ferocity02's Avatar
As far as I know the only way to do it would be to use the 60E segment and the relay mod.
Old Dec 2, 2013 | 11:42 AM
Thanks.. Sometimes I just like hptuners more lol..
Old Dec 2, 2013 | 11:45 AM
BlackGMC's Avatar
Resident Retard
I just bumped an old thread on efi live forum asking for an update on this change.
Old Dec 2, 2013 | 11:50 AM
If hp got it a while back y can't efi... it's being done more and more now.. I'll check the efi forum 2 keep myself updated on u r bump BLKGMC thanks
Old Dec 2, 2013 | 12:25 PM
Ferocity02's Avatar
You would think the EFILive guys could look at how HPT does it and figure out, but I'm guessing it's not that easy
Old Dec 2, 2013 | 01:16 PM
BlackGMC's Avatar
Resident Retard
It is just not a priority for them. They are too concerned with updating the software for new vehicles or diesels. They have not made any updates to the older pcms in a long time. Pretty much if it not a diesel or brand new they dont care.
Old Dec 2, 2013 | 01:18 PM
BlackGMC's Avatar
Resident Retard
Check out post #4
Can we get, B9021, injector minimum pulsewidth, for 1mb PCM????
I have put serious thought into buying hpt because at least they take care of the older pcms
Old Dec 2, 2013 | 01:41 PM
Gadgetized's Avatar
I did get them to add B9021 to my OS. My name on EFI Live is JUSTASBC. I had to load a stock tune in my truck, adjust it with HPT, and load it back in my truck. I then took it off my truck with EFI Live. I sent them the original tune and adjusted tune so they could see the difference. I will try to adjust the converter tge same way, but to be honest I wont be messing with my truck for a while. The guy that helped me the most with making it work was BLK02WS6. He usually reads all the tuning section so I assume he mighy chime in. If anyone knows a loop hole around something it is him.
Old Dec 2, 2013 | 02:18 PM
That's what I had 2 do for my 80swap.. now all the changes I make 2 it still keep it locked because I adjusted it with hptuners... I have both file I wouldn't mind sending them in but who knows... I'll email them may b they will take some time to look over the files...
