4L80E guys - what are your desired shift times set at?
Old May 5, 2006 | 01:55 PM
thunder550's Avatar
High on diesel fumes
Default 4L80E guys - what are your desired shift times set at?
Stock is .4 down low and .3 up high....what are you guys running? Any problem with setting it all to 0?
Old May 5, 2006 | 02:00 PM
kbracing96's Avatar
It like a 60, set it to 0 and it will disable learning and use the base pressure to set shift firmness.
Old May 5, 2006 | 02:01 PM
thunder550's Avatar
What changes when you are running vacuum modulated instead of PCM controlled?
Old May 5, 2006 | 02:12 PM
kbracing96's Avatar
Humm... That's a good question. I forgot you had that put on there. Since your line pressure is now controlled, buy the vac mod, I would say you would probably still set it to 0 and adjust the shift firmness with the setscrew in the vac mod. Probably wouldn't need to change anything though.
I would think that the PCM might get "confused" trying to maintain a set shift time with it not having any control over the line pressure.
Old May 5, 2006 | 02:20 PM
thunder550's Avatar
I think you're on the right track....got this response over at LS1Tech
https://ls1tech.com/forums/showthread.php?t=501929
Go5.3tt06
Sep 12, 2015 09:29 AM
dantheman1540
Jul 24, 2015 01:50 AM
lxcoupe
Jul 21, 2015 02:12 AM
lxcoupe
Jul 14, 2015 10:14 PM
zaathur151
Jul 6, 2015 10:57 PM
