4l80 Swap Help
Old Apr 2, 2007 | 09:25 PM
gmforlife's Avatar
Originally Posted by Wilde Racing
I'm not sure, but When I got my trans hot, around 300 deg the "Message Center" told me "SHUT ME OFF YOU MORON!"
well i took both speed sensors off and sprayed them with WD-40, so i guess when i can afford some more gas i'll try it again.
Old Apr 2, 2007 | 09:30 PM
Flyer's Avatar
Make sure the connections to the PCM are good.
Old Apr 2, 2007 | 10:02 PM
gmforlife's Avatar
yah i did that a few days ago, seemed to be alright, and in the correct location. Has anyone switeched these wires around and had similar problems as me? Cause what if they were just labeled incorrectly?
Old Apr 2, 2007 | 10:14 PM
Wilde Racing's Avatar
How do I change this text
which sensor are you going too? they are both the same, but I was just wondering.
Old Apr 2, 2007 | 10:59 PM
desTRUCKtive's Avatar
did you do a complete write on the PCM. it sounds to me like you still have the 60E file on it. is it shifting fine. I would try to do complete write with another 80E file. I am thinking it is the file.
Old Apr 2, 2007 | 11:41 PM
gmforlife's Avatar
I have the existing sensor going to the rear one on the tranny, and the one from the conversion going to the front sensor.
Old Apr 2, 2007 | 11:43 PM
gmforlife's Avatar
Yes, i have swapped out computer's twice now, and did full writes on both. Now i just swapped the original back in, and rewrote. I am still getting transmission hot, but no check engine light now. I still have the comm. codes, but i guess those are there forever. It's gotta be the speed sensor. It's the same amount of time on the freeway. It has come up twice at the same exit coming from my house. That's gotta mean something. It's only freeway. Is there a way to test the VSS's?
Old Apr 3, 2007 | 12:04 AM
gmforlife's Avatar
Just figured it out. I had a feeling it was one of the speed sensors, so i went intot he PID's and loaded up input and output and turbine rpms and my input read 0.00 and turbine read 0.00 and output read just fine. Here's the scan.
File Type: hpl
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Three6GMC
Aug 28, 2015 07:56 AM
SloSVO
Aug 11, 2015 07:33 PM
GM-only
Jul 19, 2015 10:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
