4.2 I6 wont start after engine change???? HELP!!
Old 02-20-2012, 12:11 PM
nitrorocket's Avatar
Default 4.2 I6 wont start after engine change???? HELP!!
I have a 2002 trailblazer LS with a 4.2 I6. Truck ran perfect, but developed a rod knock.
So I purchaced the same year engine from a salvage yard with lower miles and installed it. Now it cranks but will not start.
I hooked up my EFILIVE tuning software and get these codes even immediatly after they are cleared.
-P1681-Control Module throttle position(tp) system
-P1635-5 Volt reference 1 circuit
Truck cranks but will not start, I smell fuel from the tail pipe, and both the CEL and Reduced engine power lights stay on.
Keep in mind, the truck had no lights or peoblems at all before I swapped the engine so I am not sure what could be the problem.
I swapped throttle bodies between the motors and still nothing.
Any help and ideas would be appreciated.
Old 02-21-2012, 09:26 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Double check all your connections and make sure you re-connected all your grounds. Its possible that something appears to be pluged in but did not click all the way. Physically check them.
Those are the only 2 codes showing???
Old 02-21-2012, 11:55 PM
DR132's Avatar
was the replacement motor a complete drop in or did you swap over your sensors, injectors, plugs, coils etc?
ARC
57
02-21-2022 10:54 AM
thunder550
10-08-2015 04:53 PM
steves86ta
07-28-2015 10:21 AM
atxlt
07-20-2015 11:06 PM
bsgiffor
07-19-2015 11:14 AM
Quick Reply: 4.2 I6 wont start after engine change???? HELP!!
