2010 truck tuned wont burn out?
Old Jul 18, 2014 | 07:42 PM
  #31
Jason Z69's Avatar
Mine don't. Its just more responsive. The responce is way better but not bad
Old Jul 18, 2014 | 08:21 PM
  #32
Ricksilvy's Avatar
Get a converter.
Old Jul 18, 2014 | 09:04 PM
  #33
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by BIGDADDY1969
Its torque management .. Dont kno why but it took several days (more like a whole week of daily driving) after turning off my torque management in the tune for me to finally power brake a good burnout.. I reloaded my tune several times also before it finally took it but i may initially not waited long enuff for the tine to adjust.. The computer wouldnt just switch to zero torque management after the flash it takes some miles on it to adjust itself ...i have newer 2010 6l80e and pcm swapped in my 08...
That makes no sense whatsoever. It's an electronic computer, there is no reason it would take time for a setting to change from on to off.
Old Jul 19, 2014 | 07:00 AM
  #34
TIM Z's Avatar
11 sec. Truck Mod
As to the topic of this thread , I have also experienced this .
Bieng the middle man with my HPT software , i was helping my friend tune his 2007.5 2500HD LY6 6.0 and 6L90E . All stock no mods just tune only at the moment . One of my good friends tuning it
The truck after the tune ran great , we were very happy , but he , Like the original poster , wanted to be able to power brake the truck a little , hence part of reason why he wanted it tuned .
So after loading the tune and driving around awhile , happy with the shifting and better performance , we stopped and tried power braking it , it would start to , then stop and go again . Hmmm wierd , tried it again , both pedals to the floor and it just felt like it had pulled a ton of timing till he let off the brake .
I went into the tune and found a value in the trans table that I felt was causing the problem , turned it off and reloaded the tune , seemed to fix it .
But my friend says it again sometimes won't power brake , so something is still retarding the timing when he tries , i have more tinkering to do , it's weird .
I'll take a screen shot of what I changed for you to try as soon as I get on my laptop , on my phone now .
Old Jul 19, 2014 | 08:20 AM
  #35
Txblue's Avatar
Ok I appreciate it
Old Jul 19, 2014 | 04:35 PM
  #36
TIM Z's Avatar
11 sec. Truck Mod
How do these tables look in your tune ? Anyway for you to tell ?
They should look similar to these under torque managent .
Old Jul 19, 2014 | 05:44 PM
  #37
Txblue's Avatar
I tried looking but the option to view or adjust anything is locked.
Old Jul 19, 2014 | 05:51 PM
  #38
Txblue's Avatar
Once my friend is back in town we will relog the truck. Driving it harder this time and also try to burn out. That should give them better information. And I have full faith they can get it worked out they are really good. On the first log we just drove around and did one full throttle run. And I did not tell them I wanted to burn out either. I don't know much about tuning and just thought there was a way to turn torque management down or off and that was it. I didn't know there were so many adjustments. So with the somewhat week first data log and only having a muffler and MIT on the truck they probably just tuned it to be more responsive and shift better and that was spot on really happy with that.
Old Aug 1, 2014 | 10:19 AM
  #39
Txblue's Avatar
The code in the glove box shows the truck to have 3.08 gears. I can't believe they did that in a 4x4
Old Aug 13, 2014 | 06:40 PM
  #40
TexasGMC08's Avatar
On the Shift Torque Factor you can change that table from 1.000 to .5000 and will give it and quicker firmer shift.
