2005 Silverado Paracitic Battery Draw Found
Old Nov 11, 2023 | 09:16 AM
therock's Avatar
How do you setup to check voltage drop across the fuse?
Old Nov 11, 2023 | 10:18 PM
strutaeng's Avatar
5 Year Member
Just measure the DVOM test leads at each contact at the top of the fuse. It should be zero.
On that photo I posted the Klein is in-line on one batter cable and connected to the battery (Don't crank the engine though.) It's reading 0.33 Amps which is 330 milliamps.
The Fluke DVOM is measuring 0.002 volts across that fuse, which is the problem circuit fuse. When I pulled that fuse the amps dropped to 0.01 amps, which is 10 mA.
There's charts available that can tell you how much amps you are drawing based on the voltage measured and amp rating of the fuse.
You should have about 40-50 mA draw at most when everything goes to "sleep."
Old Nov 12, 2023 | 08:33 AM
therock's Avatar
Originally Posted by 01WS6/tamu
Take it to a dealer or shop and have the BCM, HVAC module and the driver and passenger door modules re flashed with newest updates
Thanks, I will look into this. I take it this is the language I should use when I ask? Or is it a basic flash any TSB's available but for the PCM & TCM?
Joe SixPack
Aug 24, 2013 03:08 PM
ASkipper
Aug 4, 2013 10:24 AM
DR132
Jun 7, 2012 09:34 PM
Go5.3tt06
Aug 18, 2011 07:19 PM
therock
Dec 16, 2010 01:27 PM
