2005 cluster question
Old Nov 29, 2014 | 08:37 PM
trxmxzx's Avatar
13 Second Truck Club
Default 2005 cluster question
My wife has a 05 sierra and the original cluster everything worked except the prnd321. So first thing change was the rocker switch for dimming dash seeing it was funky and would change dimness while driving. So I figured it's the cluster seeing they have issues.
I bought a 05 denali cluster for a trans temp and hoping the PRND321 would show up
Well still doesn't work. Would my trans shift indicator be bad? Hard to believe i have two bad clusters with this issue
Also the new cluster won't let me see miles with the steering wheel controls now wtf
But I can push the button on the dash and it changes
Old Nov 30, 2014 | 10:19 AM
1FastBrick's Avatar
Custm2500's Rude Friend
The programing is probably different between the 2 clusters.
It is possible that both displays are bad. Without seeing it work in a another vehicle how do you know it was good???
Even the display at the bottom can go bad on those things. Sometimes the circuit boards also go bad.
Old Nov 30, 2014 | 10:35 AM
trxmxzx's Avatar
Thanks man, I guess I'll have to find another truck to swap it to check. The programming you speak of that would make the one steering wheel control not work? Would a tech 2 be able to reprogram?
Old Nov 30, 2014 | 10:42 AM
1FastBrick's Avatar
The tech2 can not reprogram on its own.
You also need to know what your doing when flashing files into differnt modules.
Old Dec 1, 2014 | 01:51 AM
Suburbazine's Avatar
If the PRNDL does not light, there is an issue with the cluster. A faulty NSS would simply cause no gears to be highlighted.
The controls not working is a result of the programmed RPOs in the cluster not matching the RPOs programmed in your BCM.
Old Dec 1, 2014 | 09:06 PM
Gotta take it to a dealer and get the cluster reflashed to match the VIN of your truck for all of the DIC functions and displays to work correctly. Wont do anything for the PRNDL. You need another cluster or vehicle to swap between to verify operation.
Old Dec 1, 2014 | 10:23 PM
trxmxzx's Avatar
Perfect that's all of the possible answers I was looking for thanks for the help!!!
Old Dec 1, 2014 | 11:24 PM
turbodriven04's Avatar
Registered User
Can you solder? I'll tell you exactly how to fix your original cluster.
Old Dec 2, 2014 | 07:56 AM
trxmxzx's Avatar
Sure can!!
Old Dec 2, 2014 | 09:26 PM
Registered User
PM me.
zachman078
Sep 21, 2015 04:36 PM
brandon6.0
Aug 19, 2015 07:48 AM
08lambochevy
Aug 14, 2015 07:50 PM
Matt C.
Aug 1, 2015 01:25 PM
USMCvet0311
Aug 1, 2015 07:45 AM
