2004 Electric Fans and HPtuners... need help
Old Feb 27, 2010 | 03:16 PM
foose04's Avatar
Default 2004 Electric Fans and HPtuners... need help
After some searches, I found I need to download a beta? Where I get it or can someone please send it to robmelcher@msn.com
I have electice fans and use the Blackbear harness, pins 42 and 33, but fans wont come on.
Thanks, Rob
Old Feb 27, 2010 | 03:18 PM
Atomic's Avatar
I have a gauge for that
You dont need the beta. Simply set your on off temps in the tune. You can command high or low with the scanner to make sure you hooked them up right.
Old Feb 27, 2010 | 03:30 PM
foose04's Avatar
I did set the temp and selected on and off temps, but truck just got hotter, no fans. Also, no luck when turning Ac on. I havent done anything inside the scanner though. I'm 100% sure on a correct install, took my time on that side it.
Old Feb 27, 2010 | 04:11 PM
Atomic's Avatar
Have you tried manually grounding the harness to see if the fans and harness both work correctly? The only thing you need to do in the tune is set the on and off temps. Using the scanner is just a quick way of seeing if the computer is working correctly with the fans.
Old Feb 27, 2010 | 04:50 PM
foose04's Avatar
Just tried it, fan low turns both fans on, but fan high does nothing.
Old Feb 27, 2010 | 05:35 PM
Atomic's Avatar
If you tried it in the scanner then its not hooked up correctly. If you manually grounded it then the harness is wrong.
Old Feb 28, 2010 | 10:53 AM
budhayes3's Avatar
PT's Slowest Truck
Are you sure that the pins to the PCM are fully seated in the connector? You should feel a light "click" when you get them all of the way in.
Old Feb 28, 2010 | 01:54 PM
foose04's Avatar
Yeah, I could see through the clear plastic when they became flush with the others and I double checked the green/blue 33/42.
Old Feb 28, 2010 | 05:35 PM
Coban's Avatar
This. Did you manually ground it?
Old Feb 28, 2010 | 11:29 PM
foose04's Avatar
Well I got a e-mail back from HPtuners help, there is a beta release they told me to use to fix the problem. The next damn problem is they said the inputs are disabled in the beta. Nice, well whats the point of paying an extra $150 for HP pro if your not going to log anything. This sucks. Looks like I'll have to buy another controller of some sort for the fans, I have to be able to log my LC-1 wideband.
