2004 Electric Fans and HPtuners... need help
After some searches, I found I need to download a beta? Where I get it or can someone please send it to robmelcher@msn.com
I have electice fans and use the Blackbear harness, pins 42 and 33, but fans wont come on.
Thanks, Rob
Thanks, Rob
I did set the temp and selected on and off temps, but truck just got hotter, no fans. Also, no luck when turning Ac on. I havent done anything inside the scanner though. I'm 100% sure on a correct install, took my time on that side it.
Have you tried manually grounding the harness to see if the fans and harness both work correctly? The only thing you need to do in the tune is set the on and off temps. Using the scanner is just a quick way of seeing if the computer is working correctly with the fans.
Well I got a e-mail back from HPtuners help, there is a beta release they told me to use to fix the problem. The next damn problem is they said the inputs are disabled in the beta. Nice, well whats the point of paying an extra $150 for HP pro if your not going to log anything. This sucks. Looks like I'll have to buy another controller of some sort for the fans, I have to be able to log my LC-1 wideband.
