06 efans not working on high
Okay so when I command fans on low they come on normal. When I command fans on high the relay just clicks and clicks and clicks doesn't power on. I troubleshot it a little and the blue and green wires on the relay side and they work as they should by ground out the low and high side. What I've gathered from the PCM side is green low when commanded grounds out like it should. When I tested to continuity on the high side it just made the same clicking to my meter.??? Wth is really going on?
ullose272
Jul 19, 2015 04:14 PM
