04 Silverado - Intermittent Cranking Issues
Old Sep 22, 2010 | 09:13 AM
teesee150's Avatar
Default 04 Silverado - Intermittent Cranking Issues
My 2004 Silverado with a 5.3L is having problems starting randomly. When it happens, the truck will not crank. When I turn the key, everything shuts off in the truck like it is going to start, but it does not crank. Usually if I try several times it will eventually start just like normal and will work fine for a few days. This past Saturday is the first time it wouldn't start and I had to let it sit overnight, then it started first try.
I've checked the Range Switch and that seems fine. PRNDL are all indicated correctly as well when I shift through gears. SES does not come on either.
Any ideas on what I should look at? The truck is completely stock and no major work has been performed on it recently.
Old Sep 22, 2010 | 11:29 AM
Bow-Tie-Beast's Avatar
Check the wires on the starter, they could have worked themselves loose and you would get a signal sometimes and not others. I would also check the battery and the alternator.
LCHEE
Oct 24, 2020 04:10 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
bsn1989
Jul 16, 2015 08:20 AM
MileHighSierra
Jul 12, 2015 12:23 AM
GreyChevy
Jul 7, 2015 08:57 PM
