04 pcm compatible with 05
Old Feb 21, 2007 | 06:51 PM
doublenot's Avatar
Default 04 pcm compatible with 05
I'm getting ready to do a 80e swap and found an 04 pcm I was thinking I could use for a spare and just get it programmed for the 80. Then when I swap the trans I could just swap the pcm also. Does anyone know if there are any differences between the 04 and 05 pcm's?
Old Feb 21, 2007 | 07:41 PM
Zick's Avatar
Are they the same part #?
Old Feb 21, 2007 | 08:07 PM
dc_justin's Avatar
Hello Dave
Yes, an 04 PCM will work just fine. I've done it a number of times without any problems.
Old Feb 21, 2007 | 08:42 PM
Phantom's Avatar
11 Second Club
Hey man i seen the post you had over on efi lives forum...what'd you ever find out about swapping an '05 pcm into say an '06-7?
Old Feb 21, 2007 | 08:54 PM
dc_justin's Avatar
Hello Dave
Will actually be trying that this weekend. Will be using an 05 Custom OS on a 2006 truck. I suspect there will be no problems.
Old Feb 21, 2007 | 08:56 PM
Phantom's Avatar
11 Second Club
Lemme know how it works...just traded in the '05 for an '07 classic
Old Feb 21, 2007 | 09:09 PM
Coban's Avatar
How does the 04 control the fans?
It does have the one control, but i thought the 05 and up controlled them differently
Old Feb 21, 2007 | 09:41 PM
foff667's Avatar
LS1TECH Sponsor
yeah I belive the 04+ are similar if not identical computers...07's are 50/50 some are the classic pcm & some are the E67? I think.
Old Feb 21, 2007 | 09:53 PM
dc_justin's Avatar
Hello Dave
If the proper wiring is there on the harness and the 05 calibration has them configured like it should (stock setting), it won't matter which PCM it is.
Justin
Old Feb 22, 2007 | 06:23 PM
logan214's Avatar
I got an o4 pcm from Allen Nelson for my 06 STS Denali about 8 months ago. I have always been curious about this question myself. I still have my 06 pcm and HPTuners now. Truck doesn't run that good as it did before the STS install but I am working on logging and getting it back to Allen for a refresh. Please keep us updated on this topic.
