03 Yukon question
Old Mar 21, 2010 | 09:27 PM
Nosbaby's Avatar
Default 03 Yukon question
my wifes yukon has a bad idle problem. it just started a few weeks ago. sometimes it idles fine and then it will start surging up and down. the only codes im getting are p0171 and p0174 both showing bank 1 & 2 lean. I just changed the plugs, wires, fuel filter. I checked the fuel pressure, key on/engine off and I had about 52 psi. idleing it was up just alittle, then when I touch the gas a little the psi jumps up to about 58-60.
it only does this at idle. drives fine other than that.
this is a 2003 Yukon Xl with the 5.3 flexfuel
any ideas of what to check or change?
thanks
Old Mar 22, 2010 | 08:55 PM
Nosbaby's Avatar
ok so today when I got home from work, I cleaned the MAF sensor and the throttle body. and so far its idleing fine. no more surging.
hopefully it will stay this way. lol
Old Mar 25, 2010 | 08:06 PM
Nosbaby's Avatar
ok, so I spoke too soon. after 2 or 3 days of her yukon running good. it started back up today. surging idle???
anyone have any ideas of what I can check or change?
I did a search and found that the MAP sensor can cause this, can anyone tell me where this map sensor is? pics?
thanks
Old Mar 25, 2010 | 08:29 PM
KLUG'S SS's Avatar
FormerVendor
Lean codes and surging idle sounds like a possible vacuum leak.
Old Mar 25, 2010 | 09:15 PM
Nosbaby's Avatar
ive sprayed the intake with carb cleaner and no change in idle. but I didnt have a whole can, just used alittle.
and the surge comes and goes. it just ran fine for about 3 days.
thanks
Old Mar 25, 2010 | 09:17 PM
TIM Z's Avatar
11 sec. Truck Mod
Intake gaskets are common problems . Easy to change.
GM has an updated gasket.
Old Mar 26, 2010 | 05:21 PM
Nosbaby's Avatar
is there a way I can check them for a leak? I tried spraying some carb cleaner around the intake already. I didnt spray alot cause I ran out.?
Old Mar 26, 2010 | 07:59 PM
Nosbaby's Avatar
this problem just started when I installed a new K&N air filter, and I done a few searches and found that some oil from the filter can also cause this problem with the maf sensor.
I just clean the maf sensor on Monday, it ran great for a couple days, (my wife only drives a few miles a day) and on wed. the engine light came back on P0171, and P0174.
the idle isnt as bad as it was before. maybe I got some more oil on the maf sensor?
tomorrow after work I will clean the maf again and see what it does. also might try another air filter.
if that dont work, I guess I will have to change the intake gasket.
thanks
Old Mar 28, 2010 | 05:59 PM
Nosbaby's Avatar
still having a problem. cleaned the maf again, and the engine light came back on,
(2) bank 2 lean
(1) bank 1 lean
and it still surges alittle at idle.
any more ideas?
thanks
Old Mar 31, 2010 | 09:37 PM
Nosbaby's Avatar
I am finally gonna have a day off this weekend so I will have some time to work on her yukon.
anyone have any more ideas I can try. I cant afford to take this thing to the dealer to get it figured out.
thanks
blownss27
Aug 14, 2020 08:27 AM
5.3Caprice
Nov 7, 2015 08:56 PM
Alco
Sep 4, 2015 04:08 PM
USMCvet0311
Aug 1, 2015 07:45 AM
grantpo
Jul 15, 2015 12:21 PM
