*(%(*&% check engine light
Old Oct 10, 2008 | 11:38 AM
outlawz2004's Avatar
Default *(%(*&% check engine light
Well, gas has been crappy around here for the past month. Truck was running bad last week, I threw in some seafoam and it cleared up. Truck seemed to be running fine, then this morning out of nowhere a check engine light. I cleaned the MAF, throttle body, and changed the oxygen sensors. Reset the battery and still a check engine light. Anything else I should check out. I am going to see if its throwing a code this afternoon. Seems to be running fine.
Old Oct 10, 2008 | 11:40 AM
chevrolet all the way's Avatar
hate to be random but have you put seafoam in your oil and gas? also did you change the oil afterwards?
Old Oct 10, 2008 | 11:50 AM
Yeah, I put some seafoam in the gas tank last week. I havent ran it thru the upper intake in a while.I have done this in the past without any problems, you thinking it may have messed something up.
Old Oct 10, 2008 | 11:58 AM
i just deleted the egr and it looks awful in there and i have 87k on the clock so i wanted to see if it would make a difference. i have a can beside me. should i change the oil after its used?
Old Oct 10, 2008 | 11:59 AM
00ChevyScott's Avatar
Wearin' da big hat
I hate seafoam. Used it a few times on the old motor, only seemed to make things worse, and ive heard alot of bad stuff about it.
I'd get the code checked out asap.
Old Oct 10, 2008 | 12:01 PM
wow i havent heard anything bad about it yet... maybe i should search a smidge more
Old Oct 10, 2008 | 12:02 PM
Wilde Racing's Avatar
How do I change this text
chech the codes... I bet you have a 02 code.... Autozone does it for free,,,,
Old Oct 10, 2008 | 12:27 PM
Yeah, going get them to do it on my way to work this afternoon. I am thinking the same thing.
Old Oct 10, 2008 | 04:26 PM
Went to autozone and had to endure a fat chick flirting with me just to get my scan done. Turns out either the gas cap wasnt on good or the cap itself is loosing pressure. I will find out if it comes back on or if I was just a dumbass and didnt put it on right.
tweeder
Sep 18, 2015 11:02 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
hackrst
Jul 11, 2015 11:17 AM
