Would more of you buy stainless works
Old Sep 1, 2009 | 07:40 PM
Mangled03gmc's Avatar
Baltimore Whore
Arrow Would more of you buy stainless works
Headers if they offered a 3 inch Y pipe set up??? Or a 1 7/8 header kit??? Just wanting some feedback, as I am talking to them about it, need some positive feedback from you truck guys... So would you or more of you consider them ig they offered either one of them configurations.... Thanks BTW if you have ?? on pricing PM for it
Old Sep 1, 2009 | 07:49 PM
DBYRD's Avatar
yes and if they were cheaper id buy em quicker if they have the same clearance issues my pacesetters have with the steering shaft they can keep them.
Old Sep 1, 2009 | 08:04 PM
Baltimore Whore
They def don't have any issues, I get the deals (keep it to a PM) But i really would like to get feed back,,,,......
Old Sep 1, 2009 | 08:06 PM
GMCtrk's Avatar
I want what ARH offers with the 1 7/8" tubes, high velocity 3" merge collector and no slip fit joints. Basically I want what ARH offers, but they are not making a Y pipe for 99-06! Too busy supposedly.
Old Sep 1, 2009 | 08:13 PM
Baltimore Whore
I can tell you I highly doubt that SW will not make them with the same connection style as AH.. If it is done right, you will not have any leak problems whatsoever with a slip fit... Sure if you use junk hardware you will have issues down the road, if it is good stuff no probs. I used stainless t clamps and not a single leak...
Old Sep 1, 2009 | 08:39 PM
GMCtrk's Avatar
not interesting in slip fit thank you. It's inferior. Check what GM uses on the stock exhaust and get back to me. Ive had too many problems with slip fit in the past, especially with out of round pipes, and I dont want to deal with it anymore.
Old Sep 1, 2009 | 08:48 PM
Mr. Sandog's Avatar
Can't you weld a slip fit if you don't like it?
Old Sep 1, 2009 | 08:49 PM
Baltimore Whore
One being that you prob used reg style muffler clamps to seal it or low quality thin wall exhaust tubing... 2nd just because gm uses a diff style means nothing.. I had my pipes off a few times already and 0 issues.. And if it is all stainless you have 0 rusting problems that occur when you use mild steel So with that being said, yes if i had to use mild steel I would prefer a diff connection/joint, but being all GOOD STAINLESS slip fit is more then enough, you won't have issues...
Old Sep 1, 2009 | 08:50 PM
03 BLACKOUTSSS's Avatar
Thats the exact reason I had flanges welded onto my Pacesetters. Absolutley worth the extra $100 bucks.
Old Sep 1, 2009 | 08:56 PM
RandomHero's Avatar
FWIW Corsa exhausts are GM approved and they all utilize a slip fit design with clamps.
I never considered SW headers because of the price. Especially with the LPP headers out it's hard to justify the increase in cost.
