TV Mount Opinion
Old 08-15-2009, 08:20 PM
Where's the Beef?
viciousknid's Avatar
Default TV Mount Opinion
I picked up a 42" tv and I'm wanting to put it up on my wall but the Wall mount suggestions wants it mounted onto 2 studs with 4 screws. However where I want to put the tv i can only use 2 screws in 1 stud in the center and then use two more on the ends into sheet rock for support since it wont reach across all 3 studs.
Can I get away with using 2 in the center stud and then 4 in the sheetrocK? The tv weighs less than 47lbs.
Below is a pic of what I mean. Each vertical line is a stud and the square is the mount. The TV is currently just up on my dresser with a platform under it for more height.
Where's the Beef?
Edit: I've thought about dropping the sheet rock and putting a coupld 2x4 supports across the studs but that would be more work I'd like to avoid.
btw. that's Germ X
Old 08-15-2009, 08:22 PM
Wearin' da big hat
00ChevyScott's Avatar
Originally Posted by viciousknid
btw. that's Germ X
you've been here way too long
Old 08-15-2009, 08:23 PM
Where's the Beef?
lol.. yes I have.
And the tube to the right is toothpaste
Old 08-15-2009, 08:36 PM
Resident Retard
BlackGMC's Avatar
go buy some 1/8 inch thick steel bars, and then cut them long enough to screw into the 3 studs mounting them horizontally, then attach the mount to the steel bars....
Old 08-15-2009, 08:44 PM
Tribe Shaman
PappyDan's Avatar
cut a peace of 3/4 ply wood to go over the 3 studs.
mount your beacket to the 3/4 ply wood.
drill holes the size of screws, use at least 2 1/2 inch to secure the ply wood to the wall.
hang your tv and enjoy.
Old 08-15-2009, 08:51 PM
Where's the Beef?
both ideas had crossed my mind. I think the steal bars would look cleaner as I can paint them to match.
I'll see what I can find.
Old 08-15-2009, 08:57 PM
Resident Retard
BlackGMC's Avatar
home depot should have the bars.
Old 08-16-2009, 03:25 AM
GFYS and STFU
Spoolin's Avatar
Is the mount swivel or stationary?? If it's stationary you should be fine. Mine swivels and extends ALOT and I needed to put them in the studs. Also you can drill in a couple more holes in the center stud and mount it with 4 screws in the center and 2 in the drywall on either side. This is all assuming it's not a swivel mount. Just a thought
Old 08-16-2009, 08:55 AM
dlt76028's Avatar
the tv's not that heavy, I would just screw into the stud like you said and then use some 50lb mollys for the sheet rock.
Quick Reply: TV Mount Opinion
