Should I Lower It?
Old May 23, 2007 | 07:15 PM
Registered User
Default Should I Lower It?
Ok, so I've recently been working on my truck and now I'm at the part where I don't know if I should lower (not slam it) it or not. I'm really considering lowering it closer towards the Chevrolet Silverado SS height. There's a bunch of "offroaders" here that all have their trucks raised and I definately do not want to be put into that category with them.
I want the truck to be able to do decent 1/4 mile times and be able to run it at the local track (Road Atlanta). *EDIT* Thought lowering it would help improve stability.
Please give me your opinions.
2002 Chevrolet Silverado 1500 LT
Old May 23, 2007 | 07:22 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yes. Without a doubt.
Old May 23, 2007 | 07:32 PM
Registered User
How much?
Old May 23, 2007 | 07:33 PM
nightrunner's Avatar
Mr. Obvious
is it a 2wd or 4x4?
no matter what it is, it needs a 2" drop in the rear, minimum
Old May 23, 2007 | 07:35 PM
92GMCsierra's Avatar
if you want a lowered look.....
it does look good lowered!
Old May 23, 2007 | 07:48 PM
Registered User
Originally Posted by nightrunner
is it a 2wd or 4x4?
It's the Z71 version...
And, like I said... I don't really want to slam it.. Too many of those around here too.
Old May 23, 2007 | 07:52 PM
i wouldn't recommend saying the whole Mexican thing!
lol i know what you mean just even it out, that what i did......
Old May 23, 2007 | 07:53 PM
Mr. Obvious
just because its a z71, doesnt mean you cant lower it you just have to think about it a little more
you have a lift block in the rear, take it out and go to the dealer and get some 2wd ubolts and put them on and that will net you a 2" drop in the rear, which i think is what you are looking for. if you want more after that you can get another 2" front and rear with shackles and spindles
Old May 23, 2007 | 07:54 PM
trever1t's Avatar
I did a 3/4 drop on my Z71. Shackles and hangars in the rear, spindles up front with a little de-twist of the torsions. I am just slightly lower than a stock 2wd.
Old May 23, 2007 | 07:55 PM
Registered User
I reposted/edited right after I said that... Sorry anyone
