Question?
Old Sep 14, 2007 | 11:10 AM
1quick73's Avatar
Default Question?
i have a question, i used to run 15.4 with 3:42 gears, and my truck was bogging nasty at the line. i just dropped in some 4:11s with hoosier tires 27in in diameter, what do you think will be the difference in time?
Old Sep 14, 2007 | 02:07 PM
Quik's Avatar
5 year bitches!
if bogging you have to much tire...honestly run street tires for your times. alittle spin is better then bogging
Old Sep 14, 2007 | 02:17 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Your 60 should drop pretty nicely....if you can hook
Old Sep 17, 2007 | 03:47 PM
1quick73's Avatar
i went and yea it dropped from 2.34 to a 2.20 flat but i messed up my third gear and it ran 15.6 so dat really sucked the hoosiers are street there not full slicks
Old Sep 18, 2007 | 12:35 AM
low2001gmc's Avatar
Well I Guess We Wont Find Out Till You Go Back.....
Old Sep 18, 2007 | 10:13 AM
Quik's Avatar
5 year bitches!
you still dotn need tires at your times to be honest with you. i cut 2.1s consistant on a 235 good year street tire....step up to a 305 BFG street tire and pulled 1.98s and i was running alot faster times then you were
to much tire will cause you to bog!!!!!!!!!!some wheel spin is good
Old Sep 19, 2007 | 03:35 PM
1quick73's Avatar
well the thing is i actually had street tires i had 295s bf good rich cause i couldnt get ahold of the 305s but my truck didnt hook for crap, and thats that i had 308 gears when i used them, it was to much spin almost the 1/8th mile. now wit the 411s i dont think i would hook at all
Old Sep 19, 2007 | 04:11 PM
Quik's Avatar
5 year bitches!
launching is more then just tires. i would leave around 1100 rpms and pulled the times i did. just saying at times your running and power your making, slicks arent needed. theres plenty of ppl with street tires doing pretty well going faster. its when they are making decent power and larger stalls
Old Sep 21, 2007 | 10:52 AM
1quick73's Avatar
idk i need a 3000 stall and plus i messed up my tranny at the track, my third gear is slipping nasty, it really sucks, although with the gears my trucks 60ft was a 2.17 and it inproved from a 2.34 although like i said my third gear was just ruining the 1/4 mile times, what is it that you run?
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
