My "I changed My G/F's oil" rant.....
#31
like I said, I've been doing it on all types of different motors for years, and it has worked like a charm every time. a tone of grey/black **** ran out of the drain plug.... I changed the filter, re-filled it with fresh oil and its doing fine. she drove from here to New Jersey yesterday and back... and is leaving for Texas in about an hour... she says its still good on oil, and has made absolutely no noises... no overheating issues either.
#33
Actually I used to have a subscription to Consumer Reports and they did a test using a bunch of different motor oils in New York Taxi Cabs and they found no big difference between any of them, even the synthetics......
Here is a copy of the article, I used to have the actual hard copy but I lost it.....
http://home.mindspring.com/~ed_white/id11.html
#34
as i was a mechanic for almost 5 years ive seen this several times..and its all women or young girls that mainly live on their own, theres been some that i had to take a screw driver and a hammer and put into the drain plug hole and chisel the hard crust out so it can drain like 140w gear oil in 20 degree weather..
#37
Originally Posted by Blaze5509
Stick to working on MRI machines Colby.
Tranny fluid helps get some of the gunk out...
#38
Originally Posted by Colby 04
- however, you won't find me pouring hydraulic fluid into my oil
#39
Tranny fluid is not you're typical hyd. oil though, like what's found in your floor jack or forklift. Just wanted to clear that up before people dump hyd fluid in their engine and expect carbon to come out. As stated above, tranny fluid has detergents along with friction modifiers in it and IT WILL clean your engine.
Tydriver
45
Oct 23, 2015 09:19 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
