My "I changed My G/F's oil" rant.....
Old Sep 11, 2007 | 03:22 PM
  #21
silver-mod-o's Avatar
Hunt&Fisherator
Originally Posted by Catholic Damage
im not saying castrol is a horrible oil, well kinda.. im just saying, there are plenty of other oil that cost much less that are a much better quality. castrol is ALL advertising hype.
and yess, ive torn down a motor that ran only castrol. my 89 chevy suburban 350. when i rebuilt it, i ran only kendall gt-1, and when i tore it down again, the engine was in much better shape.
ive also torn down more motors that you've probably worked on, so please dont try to underestimate me.
and silver mod- what kind of bike? if the oil lubricates both the motor and the tranny, like with almost all dirtbikes, and most metric bikes, you can be causing some pretty harsh cluthch slippage and not even know it.
68 Triumph Bonneville 750...
the motor does share the same oil as the trans... but not the primary/clutch... its a whole different case, and oiling system. Trust me, I know this little bike, I've had it over 10 yrs...
Its got a Barnett clutch, and it will still slip it, its been adjusted by a race shop I know, and they say they all do it to a certain extent.... it could be the custom cams, race dual carbs, and almost 14:1 compression.....
-And please, dont try to play internet tough guy, I have ran this oil in EVERYTHING as stated above and have had no problems... so dont underestimate any of us on this forum... this is probably the biggest wealth of knowledge and "meeting of the minds" if you will on the internet...
Old Sep 11, 2007 | 06:15 PM
  #22
viciousknid's Avatar
Where's the Beef?
Great Story.
Very well written.
Old Sep 11, 2007 | 07:00 PM
  #23
Colby 04's Avatar
So you were an *** because she didn't know any better?
BTW, transmission fluid doesn't do anything when added to the engine oil. The old trick you are thinking of is tranny fluid down the carb, it softens carbon deposits in the combustion chamber. There are no carbon deposits in the crankcase.
Old Sep 11, 2007 | 08:26 PM
  #24
bigbadwolf54's Avatar
13 Second Truck Club
are you sure about that??? I'm pretty sure its water down the carb to steam wash the carbon in the combustion chambers and trans fluid in the oil to break loose the junk because of the detergents in the trans fluid.
Old Sep 11, 2007 | 08:37 PM
  #25
BlackGMC's Avatar
Resident Retard
I have heard of both, but mainly just the carb one. Most diesel guys I know of when they replace the fuel filter they fill it up with tranny fluid to prime it and clean the fuel system...
Old Sep 11, 2007 | 10:28 PM
  #26
Colby 04's Avatar
I'm certain.
Old Sep 12, 2007 | 03:43 AM
  #27
Where's the Beef?
blah blah blah... if it works it works
Old Sep 12, 2007 | 08:08 AM
  #28
Hunt&Fisherator
I wasnt an ***... I got upset because she's leaving for about a 3K mile trip and didnt even plan on checking it before she left. As soon as I realized I was lecturing her, I stopped... and just let her know the extreme importance of keeping tabs on the maintenance of her vehicle.... thats all
Old Sep 12, 2007 | 09:43 AM
  #29
kbracing96's Avatar
That's not quite true, There is a LOT of carbon in the crank case. Most of it comes from blowby past the rings. What do you think turns oil black? CARBON! All that slug in her oil is carbon sticking together. Also, ATF works well in this situations because it is a HIGH detergent oil and cleans very well. That why the inside of transmissions are so clean.
Old Sep 12, 2007 | 10:18 AM
  #30
vanillagorilla's Avatar
I did this on one of my dad's OBS work trucks with like 260,000 miles. My grandpa told me about the trick and it worked like a charm. All the carbon buildup came out and the truck is still running strong. You can use tranny fluid to clean crap off of parts too.
BTW, I'm currently running Castrol 10W-40. Not because its the best, but because it doesn't blow all over my engine compartment when the crankcase is pressurized. It's the thickest, cheapest stuff I can buy at my local store.
