How do you guys pull your engine?
Old Aug 12, 2012 | 01:04 PM
rfugio68.'s Avatar
Default How do you guys pull your engine?
Well I'm in the middle of swapping my 4.8 for an lq9 and all I have left is the motor mounts. So where do you guys lift the engine from? My buddies are trying to lift it from the headers, I was thinking maybe the cylinder heads? Or removing the intake manifold and bolting on a engine lift plate? Thanks in advance
Old Aug 12, 2012 | 01:07 PM
Atomic's Avatar
I have a gauge for that
Get some grade 10.9 10mm bolts and put them in the cylinder heads diagonal across the engine and use a chain in the between them...or you can use 2 chains and cross them.
Old Aug 12, 2012 | 01:13 PM
Nflddog1000's Avatar
Wouldn't lift from headers, I removed them found them in the way
Old Aug 12, 2012 | 01:19 PM
Atomic's Avatar
Old Aug 12, 2012 | 01:35 PM
scooter k's Avatar
Originally Posted by Atomic
This way!!
Old Aug 12, 2012 | 02:12 PM
texasglock23's Avatar
exactly, that would be perfect and simple.
Old Aug 12, 2012 | 02:18 PM
oakley6575's Avatar
Yea I used bolts in the heads like int he picture. That seems to be the best/easiest way.
Old Aug 12, 2012 | 09:00 PM
mhotrodscooter's Avatar
Dip stick tube bolt and the matching one on the other side.. Wiring harness stays with engine.
ARC
57
Feb 21, 2022 10:54 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
