Houston area concrete contractors
Old Oct 7, 2010 | 11:02 PM
lpguy's Avatar
Default Houston area concrete contractors
Im planning on either having a slab poured for a future garage or just extending my driveway beside my house so i have extra room to work on my truck.. Anyone have anyone they have used? Just shoot me a pm.. price per sq ft would be helpful too thanks.
Old Oct 9, 2010 | 12:12 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If you cant find anyone local to do it, I might be interested in doing it for you. A buddy and I do site work on the side. Im not an actual contractor but Im a construction instpector by trade here in Austin so I know a little bit about subgrade prep, rebar and concrete.
Old Oct 10, 2010 | 02:11 PM
jared91's Avatar
i am also interested in this. if i give you measurements of the area 1slow01Z71 could you give me an estimate? what all info would you need?
Old Oct 10, 2010 | 02:16 PM
1slow01Z71's Avatar
Intended use, a picture of the area youre wanting to put it in for grading purposes and time frame would be needed. Id have to call around in Houston to see what I can get concrete for a yard but it shouldnt be much more than I get it here. Depending on how big of an area youre wanting to do I could probably get it done in a weekend pretty easy as long as you arent wanting stamping, staining or brick border.
Old Oct 10, 2010 | 04:23 PM
jared91's Avatar
no staining or brick borderr, but whats stamping? and its an extension of my driveway next to the house, want to pull up the grass and make the driveway a little wider.
Old Oct 10, 2010 | 09:08 PM
1slow01Z71's Avatar
Well thats pretty easy, just depends on how crazy you want to get with it. There are a few ways to do it, the longer you want it to last the more it costs. I tend to over build a bit buy nature because I dont want to do a job twice. All I need are measurements and I can get you a pretty close quote.
Stamping is where you take a stencil while the concrete is still fairly malleable, you hammer it into the concrete and it leaves a design like its brick, or any number of designs. The design in this concrete is stamped and then obviously its stained but you get the idea.
Old Oct 10, 2010 | 09:21 PM
I wouldn't stamp it if you plan on using the area to work on your truck.
Old Oct 10, 2010 | 09:32 PM
1slow01Z71's Avatar
Stamping isnt a big deal, Ive done plenty of driveways with stamping, I dont recommend staining though on a driveway. Even though staining seals the concrete pretty well it still gets discolored and looks wierd depending on what type and how much liquid gets on it.
Ill be staining my driveway because I like the way it looks and sealing my garage floor with epoxy.
Old Oct 10, 2010 | 10:14 PM
ap2002's Avatar
Send me the size/area that you are trying to do, and need to decide of its going to be a driveway or a garage. Depending on the future if its a garage it would be a little more work, my dad does side jobs from time to time, he has been doing concrete work for 30yrs. Pm me if interested.
Old Oct 11, 2010 | 09:37 PM
I'm not saying that it would be a big deal. I'm just saying that he plans on using the area to work on his truck. An area that is subject to the occasional fluid spill and the inevitable drop of small pain in the *** parts doesn't need to be any more of a pain in the ***. Seems like it would be kind of annoying for moving a jack around or trying to set up jack stands. Just my opinion.
