Guys with painted headers...
Old Apr 19, 2007 | 09:44 PM
  #21
Phantom's Avatar
11 Second Club
i just hope mine last longer than they paint did on my pacesetters. i painted them the same color im painting my macs, but i didn't have them sandblasted, just roughed them up a little and then sprayed them...while it was cold outside
Old Apr 19, 2007 | 09:51 PM
  #22
BADMOFO's Avatar
Cuz I AM a BADMOFO
The paint is only as good as the surface it is painted on. Prep is key. Hopefully you will be rewarded for your efforts. I'm not sure about the Duplicolor brand, but I'm sure it's pretty good stuff. The VHT stuff I used was rated at 1500 degrees. They also recommended "heat curing", which I did my best to do by heat cycling the engine as mentioned above. Here is what they say:
VHT FlameProof Coating was originally developed some 30 years ago and is now used as a protective coating for the white-hot surfaces of space-bound and re-entry vehicles.
Since its inception, numerous industrial, automotive, and electrical engineers have developed new ideas for applications. These include aerospace hardware, smoke stacks, jet engines, heat exchangers, boilers, heaters, exhaust manifolds, mufflers, steam pipes, barbecues, electrical hardware, and countless other applications where resistance to high temperatures and/or weathering is required.
Application: Apply a THIN, even coat - just enough to thoroughly COLOR. Excessive build-up is not necessary or recommended. In applications requiring heavy coating, build-up should be done in stages, each successive coat being cured as recommended below. Nominal coating wet thickness .0015'' - .002''.
VHT FlameProof coatings require no primer. For most economical use of VHT FlameProof colors on ''hard to hide'' surfaces, apply a thin coat of VHT FlameProof White or VHT FlameProof Silver base coating.
Curing: VHT FlameProof coatings will air dry in 15 to 30 minutes and, if handled with reasonable care, may be put to immediate use. Heat curing method for maximum resistance to solvents, salt spray, humidity, thermal shock and heat:
15 minutes at 250°F
30 minutes at 600°F
1 hour at 800°F
30 minutes at 1,000°F
On non-traffic surfaces and where solvent resistance is not required, VHT FlameProof coatings may be used as air-dried. Curing may be accomplished by the inherent heat of operation such as encountered in engine manifolds and exhausts, boilers, heaters, etc. or by following the curing instructions below. ALL CURING SHOULD BE DONE SLOWLY.
Old Apr 19, 2007 | 09:54 PM
  #23
Phantom's Avatar
11 Second Club
i still wish someone woulda gave me the ok to stick them in the kitchen over LOL
Old Apr 19, 2007 | 09:55 PM
  #24
Phantom's Avatar
11 Second Club
love that color on the olds by the way...is it a blue or more of a teal?
Old Apr 19, 2007 | 09:57 PM
  #25
BADMOFO's Avatar
Cuz I AM a BADMOFO
Thanks! It was like a Teal Green....it was hot back in the 80's and early 90's, but got played out after awhile...lol. I was gonna paint it Z06 Electron Blue, but got rid of it in order to get the '57 Belair. At the time I only had a single garage...but now I would have room for both
Old Apr 19, 2007 | 10:02 PM
  #26
Phantom's Avatar
11 Second Club
I painted my last bike some kind of electron blue
BKnBLK05
Dec 28, 2015 08:52 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
fillpot
Jul 26, 2015 07:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
